spotlight replacement
TreeToad
Post by TreeToad »
I have an 06 Vibe with a cracked driver side spotlight. What is the trick to getting it out without breaking something in the process?
Wolfman213
Post by Wolfman213 »
What exactly are you referring to as a spotlight?
bull77
Post by bull77 »
i'm assuming the fogs -- From what I remember there's a screw that you remove and then you push in on the tabs and it should pop out. I took mine out with the bumper off which made things alot easier. edit: heres more infohttp://forums.genvibe.com/zerothread?id=23709
Wolfman213
That's what I assumed, but never heard that terminology for them before
TreeToad
Re: (bull77)
Post by TreeToad »
fog lig/spot light bright shiny things below the headlights :>)
bull77
Post by bull77 »
here's another link with the assembly infohttp://forums.genvibe.com/zerothread?id=32508
