Cheap air horn install - Harbor Freight
Thunderscreech
Post by Thunderscreech »
I picked up a cheap air horn from Harbor Freight. Usually $19.99, it was $9.99 so I figured "Why not?" I installed it over by the power steering reservoir:I wired a switch inside so I could sound both it and my normal horn:It's wired to a relay, btw, and I ran my wire through the firewall along with the rest of the main bundle. 40amp fuse at the battery.I'll get a sound clip, it's not a single tone, it alternates between the three horns for now. I'll experiment with combining the air lines. It uses an on-demand compressor that might not be able to supply air to all three at the same time, but it's worth a shot.http://www.harborfreight.com/c...94862
2003 Bare Bones
Re: Cheap air horn install - Harbor Freight (Thunderscreech)
Do they help the drive-thru line move faster? Or at least startle little old ladies?Good on the budget find!!!
Thunderscreech
Re: Cheap air horn install - Harbor Freight (star_deceiver)
Quote, originally posted by star_deceiver »Do they help the drive-thru line move faster? Or at least startle little old ladies?Good on the budget find!!! I'll find out! :DIt's more silly sounding than loud, btw. I'll record it tomorrow.
2003 Bare Bones
Water boy
Post by Water boy »
Quote, originally posted by Thunderscreech »I'll find out! :DIt's more silly sounding than loud, btw. I'll record it tomorrow.Ah....but posting it, well that is another story.
2008
47,891 Added new horns
47,900 Yokohama Avid 205/55-16 $492.40 drive out w/TPMS rebuild kits
69,036 Added sound deadening
70,395 Battery
106,019 Yokohama YK580 205/55-16 $589.19 drive out
Thunderscreech
Re: Cheap air horn install - Harbor Freight (Water boy)
haha, just came here to post the recording and found the above waiting for me. :DHere it is: http://hallert.net/images/airhorn1.mp3
2003 Bare Bones
Sublimewind
Post by Sublimewind »
I don't wanna brag... but... My "other" car.. lollol...
Sublimewind
The video... Wimpy... NOT...
Thunderscreech
Ha, nice! I've added more horns since my last message, looks like I'm doing something very similar to what you are except with various horn lengths so I can get a beefier train sound.
2003 Bare Bones
Thunderscreech
Re: (Thunderscreech)
Update! I added the following horn:http://www.harborfreight.com/c...40134It was (is?) on sale for $9.99, so I figured 'why not?' I wired it to a separate circuit from the calliope above and mounted it from the center cross-brace that's in front of the radiator, pointed downwards. It ended up sounding like this:http://hallert.net/images/airhorn2.mp3It was pretty good, but missing a little... something. So I picked up another one (same kit) and swapped out one of the horns with one from the calliope (a different note) and installed it in addition to the one above on the same circuit. It now sounds like this:http://hallert.net/images/airhorn3.mp3All in all, cheap fun that gave me an excuse to crawl around under the car this week. :DI was crossing a railroad trestle recently in the car at the same time a pedestrian was stepping over the tracks without looking around to check for trains. I must have hit a bump, because I accidentally firmly depressed the button for the 4 horns. Whoops! My goal going forward is to avoid the temptation to use it to be an annoying jerk. As this goes against my very nature, I expect it will be something of a struggle.
2003 Bare Bones
Sublimewind
LoL... I put mine on an unused foglight switch, so I can turn one set off for most of the time.. turn BOTH sets on for when I wanna be noticed..
joejoev
Re: (Sublimewind)
Post by joejoev »
I just re-installed my OEM horn as alternate to my Stebel Nautilus. It was something I've been meaning to do for quite some time. I kind of missed the little meep-meep...it was fun making fun of it. Anyway, I wired them up through a SPDT toggle switch. Flip the switch up and you get the "nice guy" horn. Flip it down for the "I'll make you poop yourself" horn.
shortbuskristn
Re: (joejoev)
Post by shortbuskristn »
Thats awesome man. I was wanting to put a train horn on mine but i kinda also dig the herby sounding horn.I might need some help with this kinda thing during the summer. Hope you wont be mad if i use ur idea.
Thunderscreech
Heh, go for it! It's cheap fun.
2003 Bare Bones
Thunderscreech
Status update: I figured out a way to get the calliope horn to fire all three at the same time. I now have 7 air horns firing at once:http://hallert.net/images/airhorn4.mp3It is... loud.
2003 Bare Bones
tribalman
Post by tribalman »
Quote, originally posted by Thunderscreech »http://www.harborfreight.com/c...40134i picked this up today, still 9.99. gonna be installing it hopefully in a few days. i'm confused on the install. i want to pull the stock horn but the instructions say to keep the stock horn. also, the stock horn only has one wire going into it, unless i'm missing one or the bracket is the negative connection. also, i want to keep the center of the steering wheel as the switch for the new horns, does this change the wiring at all? plus, the stock relay's wiring doesn't resemble the new one's at all.
None. Vibe is gone.
Water boy
Re: (tribalman)
Post by Water boy »
Recently installed a set of cheap plastic horns from Harbor Freight.Added a fused line from the batt than is the main power for the horns, thru the supplied relay.Much better than the OEM.
2008
70,395 Battery
Thunderscreech
Looks good! How's it sound? Got a recording?
2003 Bare Bones
