I recently got an 03 GT used, at 124K miles. I have no idea what kind of maintenance has been done, so what all should I do to be safe? I have already replaced the oil, oil filter, and tires, and topped off the fluid levels in the engine compartment, but what else might I need to do?
I would also definitely change the tanny fluid just to be safe. If you are in doubt replace / inspect :*serpentine belt*power steering fluid*coolant flush / upper & lower radiator hoses*check front / rear brakes / brake fluid*air filter / cabin filter*spark plugs*clean MAF sensor , change PVC valve*throw a bottle of techron gas treatment in the tank for good measure*clean off battery terminals check water in battery if necessaryI cant think of anything else. This way if everything is changed/inspected there will be no doubts as to what was serviced because YOU did it. You will also have a record of service starting from the time you owned it. That should have you busy !!! We have a member who hit 400K with regular maintenence.
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
