extra cig lighters?
midnighthunder89
extra cig lighters?
Post by midnighthunder89 »
There are only 2 things on the vibe I have found so far the first is the tiny gas tank, but i just have to get used to that i guess. One thing that I would not like to accept is only having a 12v cig lighter. has anyone added an extra one? where did you locate it? how hard is it to do? If no one has done this I may try to figure out a way to do it.
2010 Vibe 2.4L 5 speed manual.
Re: extra cig lighters? (midnighthunder89)
I bought a splitter, cost $6. They make the 3 in one as well.Here's the 3 way splitter: http://www.canadiantire.ca/AST...r.jspYou can buy them just about anywhere.
L5K
Post by L5K »
Shouldn't there be an extra one inside the center console?I've never even used mine since I have the dash plug in for 115v.
03 GT, Abyss with tupperwareTo Do List: (will take a long time)Front/Rear swaybarsStrut tower barTint windowsReplace rear bumper cover (previous owner rear-ended)Replace upper front bumper cover (cracked)Replace VVTL-i engine cover (previous owner was Hercules)
SmAshley
Re: extra cig lighters? (L5K)
Post by SmAshley »
Quote, originally posted by L5K »Shouldn't there be an extra one inside the center console?I've never even used mine since I have the dash plug in for 115v.The dash plug is primo for all applications... But yeah the centre console should have one & the adaptor is also a great fix. What are you wanting to do, and how many do you need?
2003 Vibe - 5 Spd Stock mechanical for now... just you wait Sony Cxt710 Deck Infinity Reference Series - All 4 doorsPioneer Tweeters 10' Clarion sunk into spare tire unit in Hatch....MINT 300.1 Mono Channel Rockford Fosgate - running sub 200.2 Rockford Fosgate - running speakers
Re: extra cig lighters? (SmAshley)
The 09-10's have only 1 12V socket! Well, at least my 09 base 1.8 does, not too sure about the AWD or GT off the top of my head. The only thing in the centre console is a black mat and a couple bolts!
lovemyraffe
Re: extra cig lighters? (star_deceiver)
Post by lovemyraffe »
Quote, originally posted by star_deceiver »The 09-10's have only 1 12V socket! Well, at least my 09 base 1.8 does, not too sure about the AWD or GT off the top of my head. The only thing in the centre console is a black mat and a couple bolts!I don't remember what years, but they were wired for a 12V socket inside the center console but it was not included. Some of us have put the socket in. I did it and it only cost me about $5. I'm not sure if the '09-'10 models were wired for one there or not.
midnighthunder89
I have a Gps and Ipod that I have plugged in for my long drives. I get sick of switching back and forth between them. I don't really use the 120v outlet cause gps doesn't have a plug for it and the ipod plug is awkward. I have thought of the splitter but was not sure if there was a plug that i could make look stock. my last vehicle has 4 in the front one in the back seats and one in the trunk just not used to only having one.
Whelan
Re: (midnighthunder89)
Post by Whelan »
Wow I have 2. One in my front next to the 12V plug and then another in the bottom of my center console. Although I have an 05 Matrix XR AWD.I have my GPS plugged into the cig lighter just enough so it's not actually using any power. I have the power wire then going into the dash right there and out through the windshield defroster vents. And finally the bit of cable there is tucked neatly with the vents hidden away for when I need to slap on the suction cup and GPS itself. Works great and keeps my cords out of the way. I hate cords!
2012 GLI Autobahn 6MT
I run my gps through one of these.http://www.walmart.com/ip/Musi...50794
midnighthunder89
Re: (star_deceiver)
Gps doesn't have usb.
Mine has the same charging imput as my Blackberry so it's usb cable works just fine!
04chargedvibe
Post by 04chargedvibe »
I picked one up from autozone and it has 3 plugs and a usb port. i have a radar, gps and use the usb for my phone plug
