cracked antenna base/mount
06pvibe
Re: cracked antenna base/mount (xmasguy)
Post by 06pvibe »
I think mine has an internal problem. The wife complains about the radio "cracking."I did a search and came up with this: http://www.partswebsite.com/gm...partsClick the illustration link for drawings. http://www.partswebsite.com/gm...30140
Raven
Post by Raven »
I recently replaced mine for the very same reason. I got mine on Ebay for $20.00 including the mast. When I checked, I think the base was around $35.00 without the mast, they were sold seperately. I'm not sure if the Matrix one is the same, but if it is often stuff is cheaper from a Toyota dealer.
Raven
Post by Raven »
I tried the shark fin route. Not a good idea. The OEM antenna base is actually quite a well made complicated part. It has a signal amplifier built into it. I got my price from an online GM parts dealer, can't remember which one. I can't find the Ebay seller's name, I've got about 400 feedback.
Herb
Post by Herb »
Interesting how it seems in the last couple of months antenna base damage has been rather common.Here's a thread to my experience a few years back:http://forums.genvibe.com/zerothread?id=5967
