I need info on how to remove the headlights. Not the bulbs, but the whole housing. I'm doing spray tint and i'm not risking overspray so I wanna take them out. Any help is appreciated 8)
The whole front bumper has to come off. You should see two of the three bolts holding the headlight housing in on top, but once you remove the bumper, you will expose the third bolt on the side. I'm assuming you already know how to remove the bumper since you've upgraded your grille.
