Sorry, I'm new...looking for a bolt for my battery hold down
Jimmy2006Vibe
Post by Jimmy2006Vibe »
Hi, I'm new the forums. I own a 2006 Pontiac Vibe and I am looking for the bolt that secures the battery hold down bar in the front, next to the radiator. I am currently using a zip-tie (see picture) and I'm having trouble finding what size bolt it is. If I remember correctly, 12mm socket was used to remove it.Local auto shops have been a real pain in the *** and I trying to find the bolt online but, I've been having trouble finding its size and for less than $10. thanks for your help!
keithvibe
Re: Sorry, I'm new...looking for a bolt for my battery hold down (Jimmy2006Vibe)
Post by keithvibe »
it's a 10mm bolt. I'm not sure of the thread pitch though
audiovibe
Post by audiovibe »
You should be able to take the rod to any hardware store and match it to a nut.Aron
midnighthunder89
Post by midnighthunder89 »
don't be sorry that you are new. everyone learns something new every day the best way to learn is to ask. people here are very nice and will do their best to help you. welcome to genvibe
2010 Vibe 2.4L 5 speed manual.
Jimmy2006Vibe
Re: (midnighthunder89)
I apologized just in case this question has been asked before.
keithvibe
Re: (audiovibe)
Post by keithvibe »
Quote, originally posted by audiovibe »You should be able to take the rod to any hardware store and match it to a nut.AronHe needs the bolt that attaches to the frame of the car not the nut on the rod your talking about.that will be hard to do being the nut is welded to the frame of the car.
audiovibe
Post by audiovibe »
HA!! DOH! Why was I thinking there was a rod on both sides.
Jimmy2006Vibe
Re: (audiovibe)
It was similar to the bolts nearby. Take a look at the attached picture, would it be same as bolt 1, 2, or 3?
Maoule
Post by Maoule »
The bolt is an M6 X 15mm. You could get away with anything up to 20mm long. Any hardware store'll have what you need.
keithvibe
Re: (Jimmy2006Vibe)
Post by keithvibe »
Quote, originally posted by Jimmy2006Vibe »It was similar to the bolts nearby. Take a look at the attached picture, would it be same as bolt 1, 2, or 3?non of those are exactly the same... lol The closest would be the headlight. It's got the same bolt head size and the pitch should be the same but it has the built in spacer that would rest inside the hole of the headlight. You can take the headlight bolt out to gauge the size just don't try to find one with the built in spacer you need the threads to go all the way to the top of the bolt head.you will understand when you take out the bolt what i'm talking about.
Jimmy2006Vibe
Re: (keithvibe)
OK, i'll try the headlight bolt...
Maoule
Post by Maoule »
Or... you could try going to the hardware store and asking for an M6 X 15mm bolt. This means a 6 millimeter diameter bolt that is 15 millimeters long. I pulled it out and checked in case my lack of posts worries y'all and the fact that I've worked with metric fasteners for 40 years gives me confidence that I'm pretty close on those dimensions;)
