3 jl w6 or 1 10 soundstream da vinci
vibe11
Post by vibe11 »
what subs should i put in my car 2 8 in jl w6 and a 10 inch jl w6 all version 1 or a 10inch 2000 watt soundstream da vincithey would be running off of a planet audio 900.1
DrunkenMonster
Post by DrunkenMonster »
10 JL W6, can never go wrong with JL
2005 Vibe Base with M&TKenwood KDC-MP342UAvital 4103 Alarm/Remote StartK&N Panel Air Filter, Removed Silencer, TB Coolant Bypass1998 Jeep Cherokee UKFlowmaster Super 44Cobra 25 LTD CB 2 JL Audio 10W0's / TMA 500
vibe11
Re: (DrunkenDixie)
Post by vibe11 »
and other suggestions, also which ever oner i dont put in the car i am going to sell
audiovibe
Post by audiovibe »
What are you wanting the sub to do? Do you want as much boom as possible? or do you want it just to fill the lower frequencies?Aron
vibe11
Re: (audiovibe)
Post by vibe11 »
so far i have polk audio mids and highs up front and 2 6 inch elemental designs sub in the rear door speakers. i want good sound quality, and i want to hit the all the different frequencies of low notes and at the same time i want it to be loud
audiovibe
Post by audiovibe »
I would either do the dual 8" in a ported or better yet; sell the dual 8" and the sound stream and find another original 10w6 and run dual 10w6. The 8w6 worked great in a 4th order band pass enclosure yielding great SQ and decent output when tuned in the 30-35 HZ range. The downside would be the enclosure would be 1.5 times as big as a ported enclosure.8" can get loud but it will need alot of power and a ported enclosure with a higher tuning frequency, probably somewhere in the 50-60hz range. The trade off here would be not good sound quality. I cant really comment on the sound stream woofer as I am not familiar with any of their newer stuff. At the end of the day I would rate the options as 1. dual 10w6 (if possible)2. dual 8w63. single 10w6Aron
