alternator problems
kdd5ltr
alternator problems
Post by kdd5ltr »
Anybody out there having any charging problems? My voltage at idle is down to 12.5 volts!!! Keith
2003 Vibe Gt - AbyssInjen CAIBorla exhaustEnkei RS6 18x7 with Nitto 555 - 225zr182002 Iasca Pro-street 601&up World Champion
ragingfish
Re: alternator problems (kdd5ltr)
Post by ragingfish »
quote:Anybody out there having any charging problems? My voltage at idle is down to 12.5 volts!!! KeithWhy, what should it be?
2009 PONTIAC G8
NovaResource
Re: alternator problems (ragingfish)
Post by NovaResource »
Keith, my first question is: how do you know? There is no voltmeter in the Vibe. I'm assuming you used a multimeter to check but what made you check?Mike, 12.5 is a little low while the engine is running. Normal output should be 13.5 to 14.2.
ragingfish
Re: alternator problems (NovaResource)
quote:12.5 is a little low while the engine is running. Normal output should be 13.5 to 14.2.Gotcha.
2009 PONTIAC G8
