Keyless Entry
tracylynn151
Keyless Entry
Post by tracylynn151 »
I got in an accident and my car had to be in the shop for repairs. When it came out of the shop the fob remote no longer worked. I replaced the battery but that didnt help. I tried the reprogramming but that didnt work either. When I try the steps it does the unlock and lock but then the fob still dosent work. Any ideas?
ou.grizzly
Re: Keyless Entry (tracylynn151)
Post by ou.grizzly »
Call the shop up and tell them that you lost the function, they need to fix it!
tracylynn151
Re: Keyless Entry (ou.grizzly)
Oh I will I am so mad, but I live in the city and I cant lock my car and the shop dosent open till monday. The key wont even lock the doors. I know the fob is functioning cause I had it tested. When I get to the reprogramming part where it says hold the lock and unlock button and then press lock or unlock it dosent confirm anything, could it be something else?
Did thet replace the door and forget to give you the key for it?Either way... take it back and let them fix it!
L5K
Post by L5K »
Do the power locks inside the car work?I'm thinking they may have forgot to plug in the power lock for the door they replaced, which in my experience in most cars, will not allow any of the doors to lock when you try to do it to all at once. (hitting the fob for example)
03 GT, Abyss with tupperwareTo Do List: (will take a long time)Front/Rear swaybarsStrut tower barTint windowsReplace rear bumper cover (previous owner rear-ended)Replace upper front bumper cover (cracked)Replace VVTL-i engine cover (previous owner was Hercules)
tracylynn151
Re: (L5K)
The doors lock and unlock when I hit the lock on the door but the dob or key wont unlock it. They replace the rear quater panel on the passanger side.
vibolista
Re: (tracylynn151)
Post by vibolista »
Pretty similar to a friend's Honda Civic that had the rear door replaced after a nasty accident. Fob would not work. He took it back to the shop and discovered that the lock was not wired up. They plugged it in and -Poof!- the fob worked again! Might be the same thing.
tracylynn151
Re: (vibolista)
Thanks everyone! I will let you know the outcome!
