Rear wiper spring tension
kcorona
Post by kcorona »
So I've noticed that the rear wiper has been streaking badly lately. No biggie, insert replacement time, right? Wrong. Replaced the insert and still no better. It appears the spring on the wiper arm has weakened to the point that there is insufficient pressure on the window to make a clean swipe. Does anyone have a replacement part number handy for either the spring or the entire arm on an '03 or '04? Or any suggestions on how to revive the spring tension?
'04 Shadow Monotone Base AT power pkg., + FIAMM low note horn, GM exhaust tip, GM splash guards x 4
Re: Rear wiper spring tension (kcorona)
You need something like this.Any auto part store should have them.
ou.grizzly
Post by ou.grizzly »
Here is a diagragm of the parts, it does not have a spring listed. The #1 Selection MSRP Price is about $76.00 through GM, but is available for about $46.00 online. Odd no spring is shown though. Looks like than assembly has to be purchased all-as-one.
Re: Rear wiper spring tension (ou.grizzly)
The helper springs cost $8-$12 for a pair last time I looked. They also come in diffrent sizes.
Sublimewind
Post by Sublimewind »
you sure the arms pivot doesn't just need some lube? I can't say I've seen a "lot" of springs lose their spring over time like that..
kcorona
Post by kcorona »
thanks for the replies everyone -- I was offline for a couple of days. I'll try some lube first, but will probably end up with the helper spring. Thanks star_deceiver! I didn't know those helper springs existed.
Re: (kcorona)
I use them in the winter with the giant winter-booted wiper.They dance around at highway speed without them.
kcorona
Re: (star_deceiver)
Post by kcorona »
Just a follow up -- I got some springs from surewipe.com, but they do NOT fit the rear wiper due to its rounded profile. They fit fine on the fronts however. Back to square one.
Re: (kcorona)
No luck with removing the plastic that covers the attaching bolt (#3 in Grizz's image) and trying the spring without it?
kcorona
Re: (star_deceiver)
Post by kcorona »
nope, tried it, no luck.
Vibe_dude
Post by Vibe_dude »
Quote, originally posted by ou.grizzly »Here is a diagragm of the parts, it does not have a spring listed. The #1 Selection MSRP Price is about $76.00 through GM, but is available for about $46.00 online. Odd no spring is shown though. Looks like than assembly has to be purchased all-as-one. Mine was doing the same thing....had to replace the whole arm on mine as the plastic arm stripped........very cheap.Bad toyota bad!
LOVE THAT VIBE 2003 Satilite Silver auto.......188,000kms.2006 Chevrolet Trailblazer White 4.2 Inline 6 291hp auto.........156,000kms.
Casper60
Post by Casper60 »
The back wiper does not get pulled from the glass often therefore the pivot in the arm closest to the pivot point will get sticky or seized. So as the blade wears down, tension on the blade decreases. Lift the cover on the arm at the windshield and remove the nut. Lift the windshield wiper arm off the bolt. Remember the location of the arm for reinstall. Use a penetrating oil on the pivot point and move the arm back and forth several times. You should notice that the arm flexes more as you move it. You may have to reuse penetrating oil. Then use a good exterior silicone lube spray on the pivot point. Reinstall the wiper arm and nut and close the plastic cover. Hope it works better. Had it happen to me and I found that the arm would not move and keep tension on the blade.
Casper60
Re: (star_deceiver)
Post by Casper60 »
There are a couple of tabs under the arm. Just gently pry and the cover will come up and expose the nut.
