Sony HU install ?
dvance06vibe
Sony HU install ?
Post by dvance06vibe »
I just installed a new Sony HU w/the USB front input. BestBuy had to repin the harness in order for the new HU to work. I have noticed that at half volume level the system is overwhelming so I have ordered the scosche converter to tone down the factory speakers. That being said my question is I have noticed that the sub does sound as well as it use too, will the scosche correct this problem? I have the moon/tunes package.
keithvibe
Re: Sony HU install ? (dvance06vibe)
Post by keithvibe »
with my set up my "amp turn on" wire wasn't going threw the scosche. So you will have to adjust it threw the radio.
dvance06vibe
Re: Sony HU install ? (keithvibe)
I'm getting sound through the sub it just does not thump like it did with the factory radio.
keithvibe
Post by keithvibe »
Quote, originally posted by dvance06vibe »I'm getting sound through the sub it just does not thump like it did with the factory radio.sounds like a trade off. I noticed the same thing with mine.
dvance06vibe
One thing I noticed today is that when the installer repinned the harness he must have reversed the front and rear speakers. When I fade it they are reversed. This will be an easy fix once I install the scosche. Should be able to just change the wires at that point. Would that have an affect on the sub?
