tire loss
SkateForLife86
tire loss
Post by SkateForLife86 »
I've had my car for like month (only like 5,000 miles) and my front tires have lost so much tread compared to the rear tires. I don't burn out much at all. Is it possible to lose some tire tread from redlining first and second gear a lot? When the weight transfers from the front to the rear and the front lifts a little, could that cause more loss of rubber? I have Falken Ziex's right now.thanks
dmitri
Re: tire loss (silverawd26)
Post by dmitri »
i want to see your custom exhaust too if possible.
KSNeptune
Re: tire loss (SkateForLife86)
Post by KSNeptune »
a) Stock tires on new cars are usually crap.b) The front tires are the drive tires. So Yes, they'll wear faster.c) It's slightly possible you need an alignment. Wheels not alighned will devour tires.d) You've been squeeling those tires, haven't you! That black streak on the pavement is your tread.From the above you may pick any one or more options, whichever relate to your driving style.KSNeptune
Sub-Vibe-R
Re: tire loss (KSNeptune)
Post by Sub-Vibe-R »
quote:a) Stock tires on new cars are usually crap.quote:I have Falken Ziex's right now.So he does not have stock tireAnd take a look to his mod: quote:-18" Tenzo R So for sure he does not have stock tire anymoreBut I agree with you, usually stock tire are the best you can have.
wildvibe
Re: tire loss (Sub-Vibe-R)
Post by wildvibe »
Remember every 6,000 get those tires rotated
2003 Abyss Vibe GTMoon & Tones PackagePower Package Mods: -Freedom Design Front Strut Bar-Window Tint 20% Sides and Back %35 on Driver and Passenger Door Future Upgrades: -Underdrive Crank Pulley-Borla Catback Exhaust-Injen CAI-ACT Xtreme Clutch Kit w/ 6-Puck Race Disc (Torque Capacity 351 ft.lbs.)-18" Katana - KR-7 (HyperBlack)-Eibach Springs
dmitri
Post by dmitri »
after u got those bigger wheels did you do an alignment?
SkateForLife86
Re: tire loss (dmitri)
yea i got them aligned
SkateForLife86
yep i got the ole 5speed base model.
Sub-Vibe-R
Do you have "Z" reated tire???Z tire will wear faster then regular R tire, as the rubber is softer and they stick more.
