Quote, originally posted by Caretaker »I think the bumper guard helps the car's looks; but if it doesn't cover the rounded edge of the bumper, then you end up with a nice black plateaued bumper guard that does nothing to keep knicks off the rounded edge when you pull your luggage out of your car.Not to disagree with you CT on the OEM version but the Bushwacker one for the Matrix (not for the Vibe) does cover the rounded edge nicely and is a quality accessory, heavier duty than the OEM -- downright beefy.
http://forums.genvibe.com/zerothread?id=38013 It is not guaranteed to fit the Vibe by the manufacturer -- though it does install securely, the inner lip (against the door well) is not perfectly aligned with the Vibe contours. Still I would rate it a 95% fit, and it in fact looks/works great, if you can tolerate the minor fitment issue. The outer-lip fitment is perfecthttp://
www.fixthisride.com/sho...08235also available from Ebay vendors -- look up earlier linksI will go down to the garage (snow day) and snap you a photo of the fit on my 2009.By the way Boudini, you probably want to put a post like this in the Exterior forum not here (and search there too....this topic has been done before). Welcome to Genvibe! Lets see some pix of your ride
