I got mine at the dealership. I think I paid around 12 bucks for it.
"Don't look to the government to solve your problems, the government is the problem." Ronald Reagan"They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety." Ben Franklin.
Someone said they found a replacement from an aftermarket, not sure how reliable that is. Go to the Toyota dealer and get the part. The issue is that none of the main manufacturers you see at the auto parts stores carry that size replacement, so you have to get the insert from the dealer. Toyota charges like $5-7, GM will most likely be more expensive since it is a Toyota part.
I just bought refills that were a little over twice the size. Just cut them to length and now you have four! Thanks for the reminder too bc I need to change mine out over the break.
I went to Pep boys and they had it right there in the aisle, $12 bucks and they put it on too, which at first the guy thought was tricky but it ended up being easy once he found the little release dealy! Advance auto was going to have to order it.
