Windshield sprayers
04chargedvibe
Windshield sprayers
Post by 04chargedvibe »
Just recently when i hit a bump water shoots out of my sprayers from the hood. Its never done this before and i was wondering if anyone has an idea as to why. Not a big deal but dose get old seeing water about ever 100FT in town lol. The bumps i hit are not masive or anything. Any ideas?
ragingfish
Re: Windshield sprayers (04chargedvibe)
Post by ragingfish »
might be an issue with the wiring for the fluid pump which is causing it to short anytime you hit a bump?
2009 PONTIAC G8
+1 loose connection or short!
04chargedvibe
Re: Windshield sprayers (star_deceiver)
Ill have to check it out. That dose sound like its prob it. Nothing should be wrong with the sprayers i assume right?
tribalman
Post by tribalman »
check this out if you feel the need to get to the reservoir and the pumps. hopefully you can find out what's wrong and it won't take a lot of time and effort to fix.
None. Vibe is gone.
djkeev
Post by djkeev »
Male car? My dog does this when I take him for a walk, can't just squirt in one place, does it all over town!!Dave
(o ! /o) (o)=I=(o)
Wolfman213
Re: Windshield sprayers (djkeev)
Post by Wolfman213 »
Quote, originally posted by djkeev »Male car? My dog does this when I take him for a walk, can't just squirt in one place, does it all over town!!Davehahaha so true!!!You may get lucky like mine think he's going and be shooting blanks lol, then no more squirts every 100 yds!
Water boy
Re: Windshield sprayers (Wolfman213)
Post by Water boy »
DrugsDrug treatment may be needed to relax the washer fluid tank so it can hold more fluid, decreasing the need for frequent squirting. Other drugs help tighten the pump check valve to avoid uncontrolled fluid leakage. Still other drugs are used to help empty the washer fluid tank for conditions in which the tank does not empty completely.Side EffectsThe most common, to the driver that is, side effect of drugs is dry mouth. To counteract this effect, you might suck on a piece of candy or chew gum to produce more saliva. Other less common side effects include constipation, heartburn, blurry vision, rapid heartbeat, fluid retention and cognitive side effects such as impaired memory and confusion.Please check with your auto mechanic or doctor for additional information.
2008
47,891 Added new horns
47,900 Yokohama Avid 205/55-16 $492.40 drive out w/TPMS rebuild kits
69,036 Added sound deadening
70,395 Battery
106,019 Yokohama YK580 205/55-16 $589.19 drive out
