Plastic switch covers?
jscherf92
Post by jscherf92 »
On the left side of the steering wheel there are small holes, my vibe has a rear hatch switch, a coin holder, and a flat plastic blank cover. Where can i find more plastic covers? rather than buying switches this size i would like to just get the plastic peices and drill holes for smaller switches.
JSCHERF92's 2005 Abyss Tein H.Tech SpringsBadge-less exterior w/tinted tails and 20% windowsSony/Alpine aftermarket sound systemRed LED interior/headlight/grill/underbody lights
epcIII
Re: Plastic switch covers? (jscherf92)
Post by epcIII »
Are you looking to take out the coin holder and replace it with one of the plastic pieces? The one plastic piece that is already there you can pop out to drill through for a switch. But I bet there's quite a few switches at auto parts stores that would fit and cover everything so you wouldn't have to buy a new piece of plastic.
jscherf92
Post by jscherf92 »
yeah xoxide.com sells scion oem switches that fit the same hole because of the whole toyota thing but theyre something like $12 a peice. I figured it might be cheaper if someone had already replaced them and had spare plastic peices.
epcIII
Re: (jscherf92)
Post by epcIII »
Probably might be worth stopping at an Autozone or someplace similar to see if they have something cheaper that fits. Of course, it is just plastic, so you might be able to get a black piece of plastic and trim to size.Or a junkyard if you live close. Good luck.
epcIII
Post by epcIII »
Keithvibe put some LED's in his cup holder and has a switch that looks like it fits perfectly into the coin holder near the brake--which looks the same size to the coin holder on the dash.Scroll down the thread and you'll see it: http://forums.genvibe.com/zerothread?id=35744 Maybe he can tell you where he got his switch.
epcIII
Post by epcIII »
Check out this thread:http://forums.genvibe.com/zero...71278 Quote, originally posted by ragingfish » UPDATE Got the part in today! Turns out it's the right one! So, if you're looking for extra blank plates for the left of the steering wheel, or to replace the little coin slots under the e-brake, the part you need is:88970565 COVER $2.75
gimmegimme
Re: Plastic switch covers? (epcIII)
Post by gimmegimme »
Anyone happen to know the part number for the covers on the '09s? I installed a button in one for my garage door opener but then moved that to my high beams, so I want to replace the drilled one with a new one rather than having a button that doesn't do anything.
