Has anyone painted the silver dash panels or installed an adhesive trim kit? I really want to change up the colors but id like to see pics before i spend the money. thanks!
JSCHERF92's 2005 Abyss Tein H.Tech SpringsBadge-less exterior w/tinted tails and 20% windowsSony/Alpine aftermarket sound systemRed LED interior/headlight/grill/underbody lights
If you just want to change up the color to something different, I'd recommend paint. There are some others that have done it with good results (search function),I like the silver look, but probably someday will add a trim kit to bring out a different color, texture, gloss, something.I'll probably only run it across the top of the glove box and on the opposite panel and on the power window panels. Depending on what I go for, say if it was the gloss black, I might also like that on the vents. I think restraint and class is called for in these situations, however.
I have been wanting to paint the trim peices myself, but I want to paint them the original color. They are scratched up by the window locks & the paint is worn by the radio. Seems like its a "steel" color.
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
Yeah i think im gonna go with a "salsa" red for the panels to match my seats and soon my lighting. Still not sure about painting vs a kit, $130 for a bunch of plastic seems a bit useless when even good spray paint is less than $10 a bottle.
I painted the following trim pieces with a metallic black duplicolor spray can:Window regulator switch panelsGauge rings The "chrome" vertical strips by the shifterThe main head unit peiceThe side piece to the left of the steering columnThis took me 3 of the 8oz cans from duplicolorCost $25Very inexpensive custom touch.
I think rareorange1 done a few more things than I did, but until those pics are up, you can check mine out. Just click the llink to my garage in my sig.
Neat idea using the chameleon paint! I have to ask though... whats with the black paint in the cargo area? Is that bedliner????And don't take this the wrong way, but nice straps holding the sub box
Thanks!It's actually Herculiner (think Rhino Lining). Whenever my dog rides back there, he doesn't slide around on the slick plastic anymore, plus I can just throw stuff in there with no worries of damaging the plastic.Thanks! Those are the straps that came from the factory. They do a pretty good job but there is a very small amount of play in them. Been thinking about switching to ratchet straps to remove the little play there.
