folding cargo cover photos
zekenwoe
Post by zekenwoe »
finished cargo cover http://i793.photobucket.com/al...7.jpgh ... nstruction photoshttp://i793.photobucket.com/al...4.jpghttp://i793.photobucket.com/al...6.jpghttp://i793.photobucket.com/al...6.jpgSince taking the construction photos, I have notched the deck to clear the headrests when folding and drilled vertical holes along the length of the supports to reduce the weight
Esteban
Post by Esteban »
OUTSTANDING ! But, I would go a step further & prime then paint the wood with gray enamel to match the interior.
lovemyraffe
Re: (Esteban)
Post by lovemyraffe »
Nice job!
zekenwoe
Re: (Esteban)
Post by zekenwoe »
I didn't want to ruin the new car smell. I thought about covering the bottom side too, but when its in the car you have to squat to see the bottom sideMy only regret is I should have taken a hole saw to the deck before covering to cut the weight some more
ou.grizzly
Post by ou.grizzly »
I take it you removed the plastic tab hooks on each side of of the rear quarter panels?Compression style beams that provide support, clean and simple design. Well done!
zekenwoe
Re: (ou.grizzly)
Post by zekenwoe »
yeah couple of screws, real easy
ou.grizzly
Re: (zekenwoe)
Quote, originally posted by zekenwoe »yeah couple of screws, real easyI even thought that maybe additional metal d-rings could be installed in that position, like existing ones in the the lower portion of the hatch.
Kincaid
Post by Kincaid »
Clever idea with the hinges.
CarbonJohn
Re: (Kincaid)
Post by CarbonJohn »
Nice looking cover. I remember when these things used to be standard on cars.
2010 1.8L Manual Carbon Gray
