'05 factory options - need quick help
455SD
Post by 455SD »
Hi all,Did the '05 still have a 2nd power outlet in the inside of the console and did the lid still have the extra storage compartment for the console as well? Also, was the radio that the CD slot located at the top of the unit and the equalizer and RDS(not the one with the two large control knobs for vol/tune) availible without the 6 speaker sound(tweeters in door pillar posts)? I found an '05 and am trying to compare to what my '03 had.Thanks!
EnvyGreen03
Wolfman213
Re: '05 factory options - need quick help (455SD)
Post by Wolfman213 »
IIRC, the 05+ did not had the outlet in the center console and it did not have the extra lid that the 03/04 had.
lovemyraffe
Re: '05 factory options - need quick help (Wolfman213)
Post by lovemyraffe »
The '05 is wired for the extra outlet, but they did not put it in.
On the radio question, are you looking for the 6 CD unit? That would work in an 05 without the moon&tunes (or perhaps sun&sound) It may be hard to find an 05 for sale that already has that set up, but if you already have that radio, it will work in an 05 with 4 speakers no problem.
455SD
Re: '05 factory options - need quick help (joatmon)
Post by 455SD »
Thanks for the help folks. My new Envy Green Vibe has the 6 disc with 6 spkrs, so all is great!
EnvyGreen03
