Hello All,I need a Battery Positive term mine has been eaten by battery acid I need a replacement. Anybody know a good place to order one online? Thanks You
the actual battery post of the connector that is connected to a wire from the car?If it's the second one you can buy one in any parts store for a few bucks. No need to order it online.If you are talking about a battery post they you will need to replace the whole battery.
walk in to any autozone and go to the counter and ask them for a battery post connector. they will give you one that will cost you about 5bucks.in this case factory='s any aftermarket connectorthe real question would be what caused it to melt and require you to need a new one? why was there so much acid on it?
Napa... I have a full write up on this very same subject... You need to replace the battery as well... The whole reason it's been eaten by acid is because it's leaking...
Quote, originally posted by Sublimewind »Napa... I have a full write up on this very same subject... You need to replace the battery as well... The whole reason it's been eaten by acid is because it's leaking... really? hmmm I have the same problem on my '03 after I installed mods. I noticed it, changed the terminal, still did it. after 6 years I changed the battery (cause it finally wouldn't hold a charge) and with a new battery it still does it. I can tell you for sure neither battery "leaked".
