Folks i just bought 09 vibe with 1.8l engine and thinking to install remote starter and i heard i will need key to put in module for remote starter. so question is is there nay place i can buy key cheaper or i am left to mercry of greedy dealer? second option is just buy blank key and program it put in module. cos it dont matter key is cut to put in module or not.and third is where i can find programing information for 09 vibe. tried enough but cant even find bank key for 09 vibe on net.any help is highly appreciated.
on my previous car i had remote start installed and used a valet key...my car came with a valet key and two regular keys. vibe only has 2 key with remote and no valet key...so not sure if you can get one of those regular keys with a chip inside and no remote tho.
In Canada you can get a Fortin CAN Bus bypass module. Basically plug and play for the most part. No need for a Key. The module does need to be programmed by an install shop before installation.
2009 Vibe 1.8L Manual - DBW controller, Hydraulic engine damper, S/S brakeline retrokit,22mm solid Rear ARB, urethane rear coil dampers, Front strut bar with brake cylinder brace, PIAA 410 driving lights, PRM Intake Wilwood front brakes, Lexus hood lifts
yes i installed Viper 5101 just starter and used Fortin Key over ride all its far better than any other by pass. i installed in Missisauga, canada and person hooked up power door locks, and horn and very thing installed and Tax in for $ 249 with module and taxes. it was best price i found.http://www.selectivesouned.net person name is Davis and he own the place he did a pro job. i am aircraft technician and can easily see poor workmanship. but this guy is pro for $ 250 installed it was bargain.Future shop want 350 bucks plus tax. means 430 bucks.
