Vibe starts and then doesn't start
SublimeVibe
Post by SublimeVibe »
This is the problem my Vibe didn't start lastnight after I got home,I then got up this morning and the car started.Went all day with it starting ,I then went to go home and the car didn't start.I went back to work about 4 hours later the car started got it home then it didn't start.All lights work and there is power to everything.No dim on lights when I turn key.No noise when I turn key no click from starter but I do hear the fuel pump though.
2003 VibeAWD Envy(sublime)wCharcoalPower pkg.Enkei EVO5 Hyper Black 07/08Vibe floor matsMud flaps Hood DeflectorLimo tint on rear and side windowsstainless steel insterts
ou.grizzly
Post by ou.grizzly »
Battery? Starter?
SublimeVibe
Battery is brand new.Starter? Is there a way to test the starter?
Re: (SublimeVibe)
Check the fuses and relays and the electrical connections on the starter itself. Sounds like the starter is on it's last legs.
SublimeVibe
Went outside today to see where the starter was located at ,found it then gave it a couple of taps with a hammer and the car started.So I'm guessing like everyone else has suggested thats its the starter.Going to call around today to see if anyone here in town has one.
djkeev
Post by djkeev »
Before you ante up for a new starter check all of the connections. There are multiple wires to the starter itself, make sure they are clean and tight. You then have ground points, both on the body, the battery and the engine. If the ground is loose or dirty your starter will act like you describe also.Disconnect, and clean clean clean. Draw a diagram if there is any question about what wire comes from where so you don't mix things up and create a bigger problem. Digital photos are better than drawings!Dave
(o ! /o) (o)=I=(o)
JRoscoe
Post by JRoscoe »
Did you finally get your problem solved? I've got a simular problem it will not start sometimes. Then I'll have to wait about 45 minutes without trying to start it, then all at once it'll start. I was told that the security was causing it to lock out because of the key tumblers so I had the tumblers changed ($200.00) and it is still doing it. I need to get it resolved so I can trust the reliability of it. Please, I'd appreciate any help from anyone.
ramenboy...
Post by ramenboy... »
check the search function... i kinda remember there being something about a earlier models having this prob. so far, my o4 is ok (knock on wood)edit: ha. search is your friend. found it. i would think GM would still honor this...http://forums.genvibe.com/zerothread?id=20634good luck guys, keep us posted.
de-badged o4 vibe
o2 triumph speed four
SublimeVibe
Finally got the car back from the shop a couple of days ago .I had the starter changed no problems since.The mechanic told me the starter was sticking and that it had a dead spot.Now I have a new problem the remote starter doesn't work.When I was plugging the control box back in I touched a couple if the prongs together and a small puff of smoke.Man can't win.
