Help installing autostart
MountainMax
Post by MountainMax »
Hey guys, im trying to install an autostart in my 2009 vibe using a datalink tbsl-ko security bypass module. I am having trouble finding where to put the two wires from the bypass module, it shows them connecting to pins 4 and 5 on a 7 pin connector but I cannot find a 7 pin connector on the dam car. Wndered if any of you came across this before. Please reply asap if you can help me out. thanks
.Fully Loaded 2009 Black Vibe 1SC with 2.4 Litre Manual TrannyCheck her out at My Cardomain page link below:http://www.cardomain.com/ride/3157869
VibeBear
Re: Help installing autostart (MountainMax)
Post by VibeBear »
Can you post a copy of the installation pic? Most bypass modules I've seen connect to the ODB II connector under the dash
1992 Chevrolet Camaro RS 305/5-speed, Bright Dark Teal
2009 Pontiac Vibe Base 1.8L/5-speed, Carbon Grey
MountainMax
Yeah, some do, the ones with two way ecm communication, this model does not allow that. I found my problem, the flash in the modules are at 1.5 and they had to be updated to 2.0 to work.
MountainMax
Re: (MountainMax)
lowincash
Post by lowincash »
hmm does the remote start need a separate remote control to turn on? or can you still use the remote on the key?
-- 2009 Vibe GT in Jet Black
MountainMax
It has it's own remote.....
