Oil Pump Bad!!!!!
Bocaj77
Oil Pump Bad!!!!!
Post by Bocaj77 »
Dealer called me today and told me that the oil pump went up. This could mean a new engine.
pmh013
Re: Oil Pump Bad!!!!! (Bocaj77)
Post by pmh013 »
Yikes! Any good reason why the oil pump failed, or just defective? Hope that didn't do any permanent damage to the engine
2003 Satellite AWD Two Tone, traded off at 180,126 kmNow the (fourth) catalytic converter is someone else's problem Now driving a 2007 Dodge Grand Caravan
NovaResource
Post by NovaResource »
That sucks. Let us know if they tell you a cause for the pump going south. I know you have alot of mods, are they going to try to deny the warranty or will they pay for the new engine?
slbpsi63
Post by slbpsi63 »
Damn that sucks. At least you might get a new engine out of it.
Base Vibe, Shadow Monotone, 5sp.
millster
Post by millster »
Ouch! Definitely keep us posted on what happens. That's too bad!
-Millster-
2006 Toyota Matrix XR
1995 Saab 9000CSE 2.3T
1986 Jaguar XJ6 Vanden Plas (GM Drivetrain Conversion)
2007 Outback XT EJ257 2.6L Build
ragingfish
Post by ragingfish »
quote:Dealer called me today and told me that the oil pump went up. This could mean a new engine.Dude, that's horrible! I hope you don't have to pay that yourself!
2009 PONTIAC G8
GT_03
Re: Oil Pump Bad!!!!! (ragingfish)
Post by GT_03 »
That sucks, i hope it turns out alright
Not a Vibe owner anymore
Bocaj77
Re: Oil Pump Bad!!!!! (NovaResource)
Post by Bocaj77 »
They are asking me about my pulleys (Unorthodox Racing) but I called Unorthodox and they said they will back me that the pulleys have nothing to do with the oil pump going bad.
msmyer
Post by msmyer »
quote:but I called Unorthodox and they said they will back me that the pulleys have nothing to do with the oil pump going bad. That's good!...Dealerships are cheats! Anything to not do the work! Who installed them?
‘03 Vibe with 317k and still going.............................
Other Mods: Sony X-Plod Headunit & Reflective White GVC decalMy Car at Cardomain.com... http://www.cardomain.com/id/msmyer
MA-VIBE-FAN
Post by MA-VIBE-FAN »
quote:They are asking me about my pulleys (Unorthodox Racing) but I called Unorthodox and they said they will back me that the pulleys have nothing to do with the oil pump going bad. So for the fun of discussion. If the oil pump is driven off the front of the crankshaft, and someone has replaced some of the pulley units, why couldn't they be related? This could get interesting.
Bocaj77
Re: Oil Pump Bad!!!!! (MA-VIBE-FAN)
Post by Bocaj77 »
Why would they be related? The pump still turns off of the pulley. The pulleys have been on there for 7,000 miles.
johnsoax
Post by johnsoax »
quote:Why would they be related? The pump still turns off of the pulley. That is exacly why they could be related. The Pump turns off of the pulley. I'm just trying to continue MA-VIBE-FAN's question.
Stereo Mod - Cargo carpet - Phone on ash tray. - Hidden HitchProjects: Fix CELMileage - 50050 - 31.41 MPG Ave
millster
Post by millster »
quote:So for the fun of discussion. If the oil pump is driven off the front of the crankshaft, and someone has replaced some of the pulley units, why couldn't they be related? This could get interesting.I really wanted to avoid this, but...I don't know about the Unorthodox kit, but one oft noted issue is the removal of the harmonic damper with installation of underdrive pulleys and the resulting damage to the crankshaft and bearings.The reason I wanted to avoid this topic is the fact that these claims are hottly contested, but this seems like a touch more than coincidence.I'd hate to see someone have the warranty denied on a fataly damaged engine, but this does make me wonder.Either way, good luck on getting this fixed quickly and cheaply BocaJ. Hopefully it turns out for the best and you're back on the road soon!
-Millster-
ragingfish
Boca -- did we ever find out what the deal is? What's going on?
2009 PONTIAC G8
millster
Re: Oil Pump Bad!!!!! (silverawd26)
Post by millster »
quote:Hmm, maybe I will skip some of those pulleys then. Well, don't set back too quick. There's evidence to support both sides of the argument. While some people have problems following installation, some don't, or at least don't appear to. I just wanted to bring the potential to light given Boca's issue and the increased interest in the pulleys.
-Millster-
cohocarl
Re: Oil Pump Bad!!!!! (millster)
Post by cohocarl »
quote:I don't know about the Unorthodox kit, but one oft noted issue is the removal of the harmonic damper with installation of underdrive pulleys and the resulting damage to the crankshaft and bearings.That was one of my thoughts also, but I'm not sure if this kit required removing a balancer or not. I know a s.b.c. doesn't like to run long w/o a harmonic balancer.
Sold 6/16/04 03 Vibe 5-speed, Hotchkis Sway Bars & Springs, Hooker Aerochamber, Panasonic Stereo, Hitch, Silverstars,04 Saturn Vue 2.2L Ecotec, 5-speed, 01 Stratus R/T Coupe 5-speed (wife's car) 85 Corvette 268 CompCam, 882 heads, FlatTops, 24lb injectors, Hooker Aerochamber true duals, 58mm TB, Holley AFPR, Siamesed intake base, Polished TPI.
MA-VIBE-FAN
quote:Why would they be related? The pump still turns off of the pulley. The pulleys have been on there for 7,000 miles.First off, the earlier posts in this topic didn't include your mileage since installation. But again that isn't a good thing. For example, if wheels are overtorqued, it is possible for a brake rotor warp pulsation to show up 3,000-5,000 miles later. Same could be true here. It has taken a while for the pump to fail. Keep us updated.
Bocaj77
Post by Bocaj77 »
Everything is being covered by warrenty. It is going to be rebuilt. It should be done by end of next week. Crank, cams, bearings, piston rings are getting replaced. One thing I must say I use Amsoil oil and I drove probably half hour with 2 pnds of oil pressure and not once heard one rattle in the engine. Even the mechanic thats working on my car said the damage should have been much worst. So props to Amsoil.
msmyer
Post by msmyer »
quote:They are rebuilding the engine? What cheap asses.. That is no cool. I would ask for a new engine. Good luck. Yeah...that SUCKS! Good Luck!
