Frustrated...EVAP prob! P0441 !@#$
Vibe07
Post by Vibe07 »
Hello All I have been using this site for a while now and finally joined. Its very helpful. Well I have an 03 1Z Vibe. First and only owner with about 83K miles on it. We got it in Hawaii not a lot of driving to do there. Anyhow recently I installed a Short Ram intake. Everything was good except the RPMS were crazy at first until the MAF figured out what happpened and evened out around 1500 RPMs at rest. It stayes there. Well about a month later my Check engine flips on. Then I start hearing a rough flipping type noise right behind my fire wall near the steering wheel. The clicking only happens with I hit the Gas. I took it in to get plugged up to read the code and the friggin 441 got me. I have found out now that its a combination of things. I know for sure the CCanister is bad, I get a whoosh from the tank when I open it everytime. However what the heck is the clicking noise and why does the engine sound like its gonna grind its self up, Im assuming my MAF may be going as well as my throttle positioner and Purge control valve along with solinoid? Also does anyone know what the heck the Denso 12V looking thing is that is attached to vaccum lines? I think that is bad too. Just really stressin about this problem, I got all kinds of mods as far as suspension, rims and Upgrades to throw on my vibe and now its dying on me???? Please any help would be much appreciated.
Re: Frustrated...EVAP prob! P0441 !@#$ (Vibe07)
Kaiserslautern; a Red Devils fan eh? Willkommen.
ou.grizzly
Post by ou.grizzly »
Clicking is normal as it is the VSV - you can hear it due to you installing a Short Ram Intake.Normal Idle even after a Short Ram Intake should be well below 1000 RPMs. My guess is that you FRIED your MAF as if you may not of disconnected your NEGATIVE Battery terminal before installing it or did not put it in a plastic bag to keep it from getting fouled out. As for your Evap Canister - sounds like you may need a new one.
Quote, originally posted by Vibe07 »I know for sure the CCanister is bad, I get a whoosh from the tank when I open it everytime.That is normal. When operating, the system puts a vacuum on the gas tank, part of the evaporative emissions controls The vacuum is so that any gas that evaporates gets sucked into the combustion instead of just venting to the outside. If you didn't get an air rushing in sound when you take off the gas cap after running it, then you'd have a problem. The most common cause for P0441 is a loose or defective gas cap, not sealing, so it can't set a vacuum on the tank. Sounds like thats not your problem though. Quote, originally posted by Vibe07 »I installed a Short Ram intake....about a month later my Check engine flips onFirst things I'd try would be:clean the MAF (especially if the short ram uses an oiled filter, perhaps it was over oiled)Double, triple check the vacuum hose routing to the new short ram. What kind of short ram did you get? It might be worth looking to see if anyone else here has the same short ram and had a similar CEL.
ou.grizzly
Take a look at this video: http://workshop.search-autopar....htmlTalks about trouble shooting a P0441 CodeTry what Joatmon stated above 1st - those are all likely causes too considering your situation.
Vibe07
Post by Vibe07 »
thanks for the input. This is the first I have been on in a while, I ended up replacing he CharCanister, havnt really noticed any change.However You are right I did forget to disconnect my Neg during installaiton. Im replacing the MAF next. Once again thanks guys.
scherry2
Re: (Vibe07)
Post by scherry2 »
I had hooked my vacuumn hoses up wrong and got a noisy clicking. make sure you hooked them up right.
B14CK_H4WK
Post by B14CK_H4WK »
what type of sri is it? it could be made wrong and the maf not in the right spot or something. a few days of having the cel is normal though after the sri install
Vibe07
Post by Vibe07 »
Its a Weapon R dragon intake, sri. I hooked up a scanner, I got P0451, and 6 codes, 1 pending. There was a Fuel, Comprehensive Components, 02 Snsr and 02 Htr and Misfire. Have the 02 sensors on order. This problem seems to be getting worse. If I throw the car in Neutral and cruise the RPMS jump up and down constantly from 1000 to 2000 until I come to a stop where it rests just above 1K. Also from 2nd to 5th when I hit the gas it sounds terrible, like Im grinding gears almost. I would have just brought this into the dealership but there arnt any Pontiac Dealers anywhere near me here in Germany. Any suggestions?
