2009 steel wheel specs
Nihilator
Post by Nihilator »
Just thought I'd put it out there for people looking for the info...Took the steelies off my wife's 2009 AWD Vibe (5x114). The 16" steelies had 205/55R16 Goodyear Eagle RS-A tires, a well-known and fairly craptastic OEM tire.Tire+rim weighs 40.5 lbs. OE tire spec is 20 lbs, so the rim (plus the TPMS sensor) is about 20.5 lbs.I made a convoluted measurement/guess at the offset, and I'm pretty sure it's 40mm. Can anyone verify or refute that?--Chris
keithvibe
Re: 2009 steel wheel specs (Nihilator)
Post by keithvibe »
look on the inside of the rim you usually will see the measurment.something like 6.5x45 6.5 is the width of the rim. +45 is the offset
Nihilator
Re: 2009 steel wheel specs (keithvibe)
Post by Nihilator »
I looked. I didn't see anything.--Chris
