Trying to route a backup camera's wires the right way; tried to remove the rear bumper skin unsuccessfully.I removed the four large clips on the bottom of the skin, and the two screws that are covered by the hatch when closed. What's next?--Chris
There should also be a couple Philips head screws in the wheel wells (one on each side I think).Just as a cautionary measure, you should tape the top edge of the bumper and the bottom edge of the quarter panels before you pull off the bumper skin. There's a good chance they might rub against each other so you want the tape there to protect from chips/scratches.
There's a thing with a phillips head look to it at the top of each panel inside the wheel wells, yes, but they're not screws, they're clips. I got those off, too. What's the procedure from that point, though? Pull straight back? Peel or pry? In which direction? Etc, etc.--Chris
