Has anyone here built a wedge sub enclosure to fit behind the rear seats?
headcold
Post by headcold »
I just put a sub in the trunk area, and while it sounds great, I'm not totally happy with the room it takes up, and more importantly, due to its shape, the room it wastes.The angle between the rear seat and the floor makes for an interesting wedge design if someone were to build something custom to house a sub and make the best use of the space.Has anyone done this? If so, can you share your measurements? I have a 10" woofer that I would take out of the current bulky enclosure and put into a new one. How are ideal dimensions/volume calculated for a specific woofer?
08 Base Platinum/Grey.Injen CAI. 10" sub & amp. Ground wire kit. Scangauge II. Honk on lock kit. Siren & PA. Fog light protectors. Insulated AC line. Double-height console lid. 12v outlet in console.
Sub-Vibe-R
Re: Has anyone here built a wedge sub enclosure to fit behind the rear seats? (headcold)
Post by Sub-Vibe-R »
I did built my own molded fiberglass enclosure for a 10" subwoofer.Too bad shipping is so expensive, since I do not have my Vibe anymore, this box is sitting in my closet, doing nothing but taking place. for nothing.
bull77
Post by bull77 »
Waxler6942
Post by Waxler6942 »
How much does it weigh? might be interested in purchasing this from you
2003 MonoTone Base / MT PackagePioneer AVIC-N1 with Sirius TunerPolk db6500 ( front ) Polk MMC650 ( rear )Directed 750d Amp ( underback seat ) pushing Polk Momo 12" Focal F10 18Rain Guards 2% Tint in Rear with Drips on FrontPainted Side MirrorsCustom Hood
Sublimewind
Re: (Waxler6942)
Post by Sublimewind »
Quote, originally posted by Waxler6942 »How much does it weigh? might be interested in purchasing this from youLook at where he lives brotha, international shipping... Building the wedge shaped box mentioned wouldn't be that difficult..
headcold
Re: (Sublimewind)
Post by headcold »
something like this, except much smaller in width to where it would fit exactly behind the drive side rear seat (the 40 in the 60/40 split). also where the angle of the wedge would be for a perfect fit behind that seat and floor without leaving wasted space.
L5K
Re: (headcold)
Post by L5K »
I got around the wasted space issue by stuffing a shallow mount Fosgate in the spare tire tub. Since you already have a sub though I don't know if this would work for your speaker as it's right at the minimum for what a box for that sub can be. I've never built a box with the angle to match the seat back, but It is fairly simple to build an angled one. all you need are the proper measurements to get the angle right.
03 GT, Abyss with tupperwareTo Do List: (will take a long time)Front/Rear swaybarsStrut tower barTint windowsReplace rear bumper cover (previous owner rear-ended)Replace upper front bumper cover (cracked)Replace VVTL-i engine cover (previous owner was Hercules)
Sublimewind
headcold
Post by headcold »
very cool. the angle on the wedge is 77 degrees. has anyone measures the angle between the rear seat and hatch floor?
headcold
Re: (L5K)
Post by headcold »
Do you have more pics of your sub install? Does it have to be a shallow mount sub or could I take the 10" sub out of the enclosure it's in now?
L5K
Re: (headcold)
Post by L5K »
http://forums.genvibe.com/zerothread?id=38669 That thread has all my pics of the installed sub as well as more detailed information. I didn't think to take pictures while I was building it. I should get more pictures up, and some pics of what I did inside the tub with the long posts with nuts on either end to tighten the top face down into position. I'll see about getting them up this week sometime. But pretty much, yes, it does have to be a shallow sub, and specifically a Rockford Fosgate P3SD410. The reason is that it is the only subwoofer I could find that works well with .4 cubic feet of air inside the enclosure (there may be more but I never found any). It is the absolute minimum that RF recommends for the sub, and you have to cut the bulge out of the bottom of the tub, seal the hole, modify the screw that holds the spare tire down, and then you can get to ALMOST .4 cubic feet inside the tub, so putting polyfil in the tub is a must do.It would be possible to physically install a standard depth subwoofer, depending on how deep it was, but they require much more air inside the enclosure to work properly and I can't imagine they would produce very good sound with the small volume of the tub.Just know this will not give you the same oomph as a "proper" box will, although the shallow Fosgates are much better than I thought they would be. It actually surprised me how well it worked in that small of a package.
