I gathers some parts (fogs off a toyota) and I just need a few pictures of the AWD fog lights and the trim...I saw the GT today and it looks way different from my base 09..
I would say that because the covers are angled at almost 45 degrees, you'd have to come in at that angle, otherwise you'll have an ellipitical hole (kind of like a cat's eye - or maybe the eye of Sauron, lol) that you are shining a round light thru.Unless you can set up a jig, I'd suspect it might be easiest to cut them on the vehicle. If you mess up - you can buy my old covers and try again!Does the hole saw have a center bit to keep you lined up? If so, go real slow and steady.
yea it has a center drillbit.. but another problem i ran into..the fogs are 4" in dia I have a 4 inch and a 5'' hole saw bit guess im going with a 4" and some dremel action
