2005 Bumper Grill, what's it called?
p.w.sachs
Post by p.w.sachs »
Wondering what the small grill on the lower right section of the bumper is called. It's the section that's about 6 inches wide. Also, does anyone have a link to a site that sells the item?Thanks!
p.w.sachs
Re: 2005 Bumper Grill, what's it called? (p.w.sachs)
Post by p.w.sachs »
Also, I'm a new member. So... hi!
lovemyraffe
Post by lovemyraffe »
Welcome!You could try this one http://cgi.ebay.com/ebaymotors....m245 I don't know for sure whether or not the '03-'04 bottom grilles are the same as the '05-'08.
Wolfman213
Post by Wolfman213 »
the 03-04 grilles are different from the 05-08. I'm missing both side on my 06. From what I've found unless you get lucky and find a cheap used one on ebay, they all tend to run the same price. GM Parts Direct will probably be your best bet.*update* I just checked on the prices and unless my memory is failing me, they are much cheaper than they used to be.
scherry2
Re: (Wolfman213)
Post by scherry2 »
the probably run about $30 new. they are just called a Grille, lower R or L.
p.w.sachs
Post by p.w.sachs »
You guys are great! I just bought the piece. I appreciate it!
