brake conversion
SkateForLife86
brake conversion
Post by SkateForLife86 »
Is it possible to put the rear disc brakes from a GT and put them on a base vibe? Do they have different sized master cylinders or anything, or can they be directly bolted on? and why do i have to type so slow when i write mesages to?thanks
ragingfish
Re: brake conversion (SkateForLife86)
Post by ragingfish »
quote:and why do i have to type so slow when i write mesages to? what are you talking about???
2009 PONTIAC G8
satur9
Post by satur9 »
yes its possible but ssbc's rear disc brake conversion kit is cheaper $500 its listed for matrix.
slbpsi63
Re: brake conversion (satur9)
Post by slbpsi63 »
quote:yes its possible but ssbc's rear disc brake conversion kit is cheaper $500 its listed for matrix.Is it only for an XRS? Where did you find it? I would like to check it out.
Base Vibe, Shadow Monotone, 5sp.
satur9
Re: brake conversion (slbpsi63)
Post by satur9 »
xrs already have rear disc they have a site http://www.stainlesssteelbrakes.com
russ257
Post by russ257 »
if you do this does abs still work?
'03 VIBE AWDPioneer AVIC-N1MOMO 6.5" componets in frontMOMO 6.5" speakers in rearJL e6450 six channel ampJL 12" w3 subAlpine 120W amp powering the sub
