Engine Air Filters
MajorAD
Engine Air Filters
Post by MajorAD »
Now that I have a better exhaust system on my 2.4l Vibe, I looking for a less restrictive but with a good filtering medium air filter. Ive seen drop in K&N ones but I dont like its filtering efficiency.And then you have your CAI that they dont have for the 2010 model or if they do they cost $$$.So that leaves me back to the drop in ones, has anyone use or seen a paper or whatever material that is better than the oem air filter, Puralator,WIX,Amsoil?BTW amsoil advertises a new type of AF with nano whatever tech but for the vibe it will send you to their WIX filters,any comments??
BlueCrush
Re: Engine Air Filters (MajorAD)
Post by BlueCrush »
Take a look at the aFe Pro Dry-S drop in filter. It is a dry media filter, so no oiling and easy to clean. http://cgi.ebay.com/ebaymotors....m245h ... r...ilter/
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
keithvibe
Post by keithvibe »
have a good readhttp://www.nicoclub.com/articles.php?id=180100ac delco
MajorAD
Re: Engine Air Filters (keithvibe)
Post by MajorAD »
Unfortunately aFe does not have one for a 09-10 let alone for a 2.4l engine That is the kinda filter Im looking for.
MajorAD
Post by MajorAD »
They do sell the filter for a 09 corolla with the 1.8l engine,I wonder if the filter from that would fit a 09 2.4l vibe???
dragon64
Post by dragon64 »
Quote, originally posted by MajorAD »They do sell the filter for a 09 corolla with the 1.8l engine,I wonder if the filter from that would fit a 09 2.4l vibe???No it won't the 1.8 filter is the same as for the 06+ 1.5L Yaris. Scion Xb (08+), Toyota Camry (07+)/ Avalon (05+)/ or Lexus ES350 (07+) application should work in the 2.4
2009 Vibe 1.8L Manual - DBW controller, Hydraulic engine damper, S/S brakeline retrokit,22mm solid Rear ARB, urethane rear coil dampers, Front strut bar with brake cylinder brace, PIAA 410 driving lights, PRM Intake Wilwood front brakes, Lexus hood lifts
MajorAD
Re: Engine Air Filters (dragon64)
Post by MajorAD »
Well I went ahead and replaced the stock AF with one from WIX.It has a foam like material and fits really well in the air box,still would like to get a aFE one day. Now for some "around the town " testing on mpg etc.
high revin
Post by high revin »
K&N Typhoon on mine and built a fresh air ram air ducted to it from the lower grille works great.
bull77
Re: Engine Air Filters (high revin)
Post by bull77 »
Quote, originally posted by high revin »K&N Typhoon on mine and built a fresh air ram air ducted to it from the lower grille works great.pics of setup?
high revin
Pretty simple really used a quality flexable black 3" hose ran it from the driver side lower grille and it snaked right up under the battery and ends right under the fuse box and points to the open end of the element works real nicely very simple and clean hardley noticable.Anytime you can get that much fresh air into the engine always a good thing ecspecially unubstructed cool air. matched with a good exaust Alot of people run the long tube Intakes and there a nice enough set up, but to make a true ram is pretty simple and works very effeciant.
MajorAD
Re: Engine Air Filters (bull77)
Post by MajorAD »
That is one SWEEEEET setup!!!,yes any pics esp the 3" hose installation. Unfortunately that KN cai is a little too rich for me, so for now a better oem air filter.BTW can anyone tell me if the 09 Toyota MATRIX 2.4l air filter is the same as the 09 Vibe 2.4l??
