Hood shocks installed. Kits for 03-08 Matrix WILL WORK in 03-08 Vibe
L5K
Post by L5K »
Okay, kit came today. Installation is a breeze, and the instructions are straightforward plus they have pictures.Took me longer to gather the tools than it did to install these. Works perfect. You will need for installation a ratchet and three sockets. 10mm, 12mm Deep, and 13mm. Wrenches would work just fine too.The kit itself came with four washers, two ball studs, two bolts, two brackets and the shocks themselves. Step one is to open the hood and install the brackets. They replace the upper bolts on the hinges on the hood itself. I did this one side at a time to avoid the hood possibly shifting on the hinges. When installed it will look like this. The next step is to replace the bolt that holds the fender down with the ball stud (this is why you need a deep socket). It goes way down by the headlight and looks like this when installed. Next I put some grease on the ball studs. I don't know if this would really matter, but it can't hurt, and will help keep them from seizing or anything like that. The shocks in the kit had a clip type of thing that stuck into the socket and then clipped around the "neck" of the socket. I popped them out and slipped the shocks onto the ball joints and reinserted the clips and snapped them into place. This seemed much easier than trying to force the ball into the socket. I also did this one joint at a time to avoid losing any of the tiny clips.After all is said and done it looks like this. Total damage was US$54.99 with free shipping from Kasey302 on Ebay. There are others listed, but this is the cheapest as the others are all around 50 bucks plus shipping. The original listing is here and it says he still has 5 available.http://cgi.ebay.com/ebaymotors..._1165 This is definitely an improvement in my book as I always hated manual hood props because it never fails that I need to use them in the dark. Plus the one in my Vibe was all worn out and the plastic insert that it pivoted in would let it slip right through the hole unless it was wedged in just right and always scared me to death. Took me maybe 15 minutes to install and that was while taking pictures of the process.
03 GT, Abyss with tupperwareTo Do List: (will take a long time)Front/Rear swaybarsStrut tower barTint windowsReplace rear bumper cover (previous owner rear-ended)Replace upper front bumper cover (cracked)Replace VVTL-i engine cover (previous owner was Hercules)
Herb
Re: Hood shocks installed. Kits for 03-08 Matrix WILL WORK in 03-08 Vibe (L5K)
Post by Herb »
Wow, that's a pretty simple setup. I'm almost tempted
Would you agree to debris acceptance? 2003 Vibe GTMods installed GM Top and Mid-Gate Spoilers, Cosmo CAI, TWM Short Shifter with Desert Eagle weighted shift knob, TWM Bronzoil Shifter Cable Bushings, Magnaflow Cat Back Exhaust, Unichip, Injen Billet Aluminum Engine/Sparkplug covers and oil cap, Optima RedTop Battery, Lineage Ground Wire KitAwaiting install: Energy Suspension Motor Mounts, DC Sports Header
L5K
Post by L5K »
It is really simple. I was expecting to have to realign the hood or something.Also I should note here, the instructions say that they do not recommend using these with carbon fiber, or other lightweight hoods. I don't know for sure if it's because it would make them difficult to close, or if it is because it could crack the hood.
Raven
Re: (L5K)
Post by Raven »
Nice I think I'll get a set.I hate the prop bars too.
scherry2
Re: (Raven)
Post by scherry2 »
just ordered a set. only 3 left.
Wolfman213
Post by Wolfman213 »
Definitely nice!! Keep us posted on how long those shocks hold up though. My only concern is the angle of the shocks. With such a low angle like that, there is a lot more force/weight being pressed down on the shocks.
L5K
Post by L5K »
Yeah, I'm wondering how long they'll hold up too. I kept the rod in the back with the jack just in case. It won't fit in it's place because it would interfere with the right shock. I think they should last a while though as I really don't have the hood open except when I'm working on it. The shocks were too stiff for me to depress without the leverage from the hood and I like to think I'm a pretty strong guy.
cptnsolo77
Post by cptnsolo77 »
Very cool, practical mod! Thx for sharing.
* Kenwood Excelon KDC-X597
* Polk DB651-Speakers
* Drop In K & N Filter
* NGK Iridium IX Plugs
Old Tele man
Post by Old Tele man »
...although I doubt it, wonder if there's something available for the 2009-2010 models?
...and the Devil said: "...yes, but it's a DRY heat!"
• 2014 Prius 1.8L eCVT
• 2009 Vibe 1.8L 4A
• 2004 Vibe 1.8L 4A
L5K
Post by L5K »
I contacted the seller, explaining to him that the product works in 03-08 Pontiac Vibes also, but his response seems like he didn't understand. He explained to me that they were in the process of finding out if it would work on the Vibe... :/
BlueCrush
Re: (L5K)
Post by BlueCrush »
So when you pop the hood, does it go up on it's own? Or do you still have to unhook it from the front and lift it up?
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
L5K
Post by L5K »
You still have to unhook it and lift it up. At about halfway it will stay where you leave it. When closing it, all I do is push it down till it's a couple inches above closed and then drop it. If you just push without holding it, when you get to about halfway down it will fall the rest of the way. Basically like any other car that has factory shocks/springs.
BlueCrush
Re: (L5K)
Post by BlueCrush »
Quote, originally posted by L5K »You still have to unhook it and lift it up. At about halfway it will stay where you leave it. When closing it, all I do is push it down till it's a couple inches above closed and then drop it. If you just push without holding it, when you get to about halfway down it will fall the rest of the way. Basically like any other car that has factory shocks/springs.Cool!
My Fleet:
Whelan
Re: (BlueCrush)
Post by Whelan »
1 left Not appearance improvements, I think I am done with those, but something nice to have as those little bars never made me feel secure about working under the hood. What if you hit it by accident or something and it pops and the hood falls on you.This will be much more secure and totally worth the $54 for the whole kit. The shocks alone would cost about that much.My only improvement is going to be coating the screws in Rustoleum Black paint on top to match the inside of the car and put some Lanacote on the threads to prevent corrosion and rust. I'll post up my pics when I get it installed.
2012 GLI Autobahn 6MT
ajb812
Re: (L5K)
Post by ajb812 »
I've been looking for this for my 09 GT. Anyone have any idea if this will work on the 09s, or where to look for it for the 09?
2009 Pontiac Vibe GT Jet Black Metallic
GenVibe Garage
L5K
Re: (ajb812)
Post by L5K »
You might try to see if there's a kit for the 09 Matrix.I would imagine however that the layout of fender bolts and hood hinges didn't change when they changed body styles. That would be way more work on the manufacturer rather than just using the same frame and body mounting locations with a different sheet metal over it. These would probably work, but I can't say for sure.
Whelan
Re: (L5K)
Post by Whelan »
The 09+ is an all-new car for the most part so it is very feasible that it would not fit and would possibly need longer or shorter gas struts.
L5K
Re: (Whelan)
Post by L5K »
I didn't realize they changed things that much. I know on older cars things like fender mounts, motor mounts, hinge placement and other "under" things were usually always the same from generation to generation unless it was a complete redesign.
Herb
Re: (Whelan)
Post by Herb »
Quote, originally posted by Whelan »1 left It's gone apparently. However there is a new one with 5 more: http://cgi.ebay.com/ebaymotors...3AVRIQuote, originally posted by Whelan »Not appearance improvements, I think I am done with those, but something nice to have as those little bars never made me feel secure about working under the hood. What if you hit it by accident or something and it pops and the hood falls on you.I never thought about that. Has that actually happened to anyone?
L5K
Re: (Herb)
Post by L5K »
Mine never fell, but the rod would easily slip through the small plastic sleeve in the fender and would require me to work at it a little to get it back in correctly. I doubt it would have fallen, but I didn't want to give it a chance either. Plus now, in the dark I don't have to juggle the hood, a flashlight, and the prop bar.
Herb
Re: (L5K)
Post by Herb »
Quote, originally posted by L5K »Mine never fell, but the rod would easily slip through the small plastic sleeve in the fender and would require me to work at it a little to get it back in correctly. I doubt it would have fallen, but I didn't want to give it a chance either. Plus now, in the dark I don't have to juggle the hood, a flashlight, and the prop bar.To be honest, I'm more worried on how well the shocks will work in the winter. In my previous car (Dodge Shadow) and my Vibe, the rear hatch shocks don't really keep the hatch up very well in low temperatures
Whelan
Re: (Herb)
Post by Whelan »
Your shocks must have been bad or old. I've never had a problem in cold weather with mine, they may go up a little slower, but never lost their hold. Gas shocks do have a lifespan and over time wear out. Although you are in Canada where it gets mighty colder than here in CT.
Herb
Re: (Whelan)
Post by Herb »
Well I've experienced temperatures in the winter around -35C or -31F
Whelan
Re: (Herb)
Post by Whelan »
Yeah not me, maybe once in a great while I had -20F in CT, but that was short and rare.Mine come in today according to the tracking as they came from NY so next door. I'll have them on by this weekend with pics on the Matrix.
Herb
Re: (Whelan)
Post by Herb »
I did forget to mention earlier in more moderate temperatures they behaved more normally. In the case of my Shadow, I know that was age related as well.At some point I had replaced them with a much stronger pair. In fact TOO strong, when I used the hatch release in the dash the hatch would leap into the open and extended position in about half a second!
L5K
Post by L5K »
I've had them in other vehicles too and never had a problem in winters. About like CT here, into the -20's is rare, but it does get below zero regularly at night. All numbers Fahrenheit lol. I did have a pair in my Daytona Shelby that didn't hold the hatch up, but they were in the car for a good 18 years before they went out. Plus that hatch was far heavier than the hood.
ou.grizzly
Post by ou.grizzly »
Will have to save up to purchase a pair... Need to pay summer taxes 1st.
BlueCrush
Re: (ou.grizzly)
Post by BlueCrush »
Quote, originally posted by ou.grizzly »Will have to save up to purchase a pair... Need to pay summer taxes 1st. WOW! Summers in Minnesota are free, you gotta pay for your warm weather? What kind of conspiracy is goin' on over there? I would say, "screw it" and let it snow 24/7/365...lol.Ordered a set of these as well..
My Fleet:
jkm311
Re: (BlueCrush)
Post by jkm311 »
Dang, Grizzly! This might get thrown on the mod list, too! I'll never make it to a D-town meet at this rate!
Steelies to the rescue.
ou.grizzly
Re: (jkm311)
Quote, originally posted by jkm311 »Dang, Grizzly! This might get thrown on the mod list, too! I'll never make it to a D-town meet at this rate! Yeah you will. It would be held within 30 mile miles of you... This mod actually make me open up the engine bay on my 08 Vibe. Still need to change the engine and hvac filters.
Whelan
Re: (ou.grizzly)
Post by Whelan »
Here are some additional pictures of the items received. Installing after work today Not too shabby for a Blackbery Storm 9530 3.2MP Camera Total PackageDiagramAssembly Bolts/WashersCloseup of the little clips to hold the balls in place
BlueCrush
Re: (Whelan)
Post by BlueCrush »
Nice! Let us know how it goes. Mine just shipped yesterday so they probably won't arrive until mid next week.PS - you said "balls"....lol.
My Fleet:
BlueCrush
Re: (BlueCrush)
Post by BlueCrush »
My hood shocks just arrived today, too...YAY! I'll install them either tonight or tomorrow morning.
My Fleet:
scherry2
Post by scherry2 »
putting mine on when I get out of work.
Whelan
Re: (scherry2)
Post by Whelan »
LOL! Sounds like this guy in NY saw the orders fly out after the original post and figured give himself a good rep and send fast. Let's all put up pics by tomorrow and inundate the post!
L5K
Re: (Whelan)
Post by L5K »
No fair I didn't get that little diagram for putting the studs into the sockets! I did warn the guy to expect some more sales though. lol
BlueCrush
Re:
Post by BlueCrush »
Here's my pics:
My Fleet:
bodhi_tree777
Re: Re: (BlueCrush)
Post by bodhi_tree777 »
nice. That angle still looks bizarre, though. Is it possible to modify the kit to bolt on higher up on the hood? Or does it really not matter?
Whelan
Re: Re: (bodhi_tree777)
Post by Whelan »
To be honest it really doesn't matter. You have to lift the hood a little bit but then it pops open and stays there. And when closing you bring it down to about a foot or two away and it closes on its own and locks very nicely.I'm a big fan, got my oil changed Saturday and the guys noticed the upgrade and liked it.It was definitely handy when I changed my spark plugs today cause you can easily manuever without hitting or working around the bar.
BlueCrush
Re: Re: (Whelan)
Post by BlueCrush »
One thing I did notice right away is that when the hood is fully open, it is about 2-3 inches lower with the hood shocks in their current location than with the hood prop. I'm thinking about moving them back to the open holes about 1-2/2" back from where they are located now on the quarter panels.
My Fleet:
Whelan
Re: Re: (BlueCrush)
Post by Whelan »
Quote, originally posted by BlueCrush »One thing I did notice right away is that when the hood is fully open, it is about 2-3 inches lower with the hood shocks in their current location than with the hood prop.That may be the difference. When I installed them on my Matrix I notice I had to actually raise the hood off the stock bar to get the struts to mount on the balls. If the Vibe hood sits differently it could be why they didn't claim it to fit the Vibe originally. Although a few inches is not a deal breaker for the added convenience for you guys/gals.With the new struts my bar is pretty much useless.
ou.grizzly
Quote, originally posted by bodhi_tree777 »nice. That angle still looks bizarre, though. Is it possible to modify the kit to bolt on higher up on the hood? Or does it really not matter? I am not digging that angle either; that is a bad mounting location as it is not supporting in the right place? What do ya think?Here is an older generations F-150 to compare mounting locations:
Whelan
Re: Re: (ou.grizzly)
Post by Whelan »
It could be better positioned, but this was built to be a direct bolt-on kit without drilling or welding require. Using the hood hing and front bumper attachment points.All-in-all it's still a great buy and does it's job. Our hoods are not that heavy either and these struts keep them open very well, I noticed no slipping or anything when the hood is up. It feels a lot more secure than with the pole. And if you look, the pole that holds our hood up is not that much farther away from where these mount. The only difference being the pole comes up at a higher angle.
06pvibe
Post by 06pvibe »
So I did find a few kits for the 03-08 Matrix. These will fit on the same year Vibes?
Whelan
Re: (06pvibe)
Post by Whelan »
Correct, the Vibe and Matrix mounting locations are identical I believe.
BlueCrush
Re: (06pvibe)
Post by BlueCrush »
Quote, originally posted by 06pvibe »So I did find a few kits for the 03-08 Matrix. These will fit on the same year Vibes? Yes, it is the same kit that I have on mine.
My Fleet:
L5K
Post by L5K »
Yeah, that's why I made this topic, I decided to try to see if the Matrix kits worked, and well... they do.
06pvibe
Re: (Whelan)
Post by 06pvibe »
Quote, originally posted by Whelan »Correct, the Vibe and Matrix mounting locations are identical I believe. Great. On order... from Taiwan of course. This will be mod #2, after the LED 3rd stop light.
06pvibe
Re: Re: (BlueCrush)
Post by 06pvibe »
Quote, originally posted by BlueCrush »One thing I did notice right away is that when the hood is fully open, it is about 2-3 inches lower with the hood shocks in their current location than with the hood prop. I'm thinking about moving them back to the open holes about 1-2/2" back from where they are located now on the quarter panels.Blue, did you ever try that? Because I just did and after removing the OE hood prop rod that the RS strut was hanging up on, it works like a charm. Raises the hood at least another 1.5" higher than before.You need: 2- 6mm x 1.0 nuts, and either a 4 big 6mm flat washers, or in my case 4- 1/4" flat washers. The hole is a little bigger than it has to be, but cranked down (I only used a 1/4" drive ratchet) it ain't goin' no wherez.You could also use 4- 3/16" fender washers if you are willing and able to modify them. Increase the size of the hole to 6mm and grind down the sides, but after trying it w/the 1/4" cut washers, I don't feel that's necessary.
vibolista
Re: Re: (06pvibe)
Post by vibolista »
My 'prop up stick' is still doing the job, so don't think this mod is for me... but did you (06pvibe) order the LED third brake light? I've been trying to fit in some skiing and work lately, so not enough time to attend to the LED brake upgrade. Any luck ordering the LED ?
