Question... possible problem
09vGT
Post by 09vGT »
So.. I've just started to notice this but when I take off at slow speeds.. not even fast, just normal accelerating my car whistles.. a lot.. when I'm at higher speeds I don't notice it.. Also, after taking off from a dead stop and mashing the gas to the floor when reached a higher speed, like 65 or 70 MPH, a HORRIBLE smell, like sewage, starts coming through the air vents. It doesn't last very long, but long enough for me to have to crack a window or the sunroof.. Any idea's on these two issues? Thanks!
L5K
Re: Question... possible problem (09vGT)
Post by L5K »
Did you have Bub Rub install a whistle tip for you or something? http://www.youtube.com/watch?v...ex=10 "It's just decoration, man. That's it and that's all."
03 GT, Abyss with tupperwareTo Do List: (will take a long time)Front/Rear swaybarsStrut tower barTint windowsReplace rear bumper cover (previous owner rear-ended)Replace upper front bumper cover (cracked)Replace VVTL-i engine cover (previous owner was Hercules)
keithvibe
Post by keithvibe »
Has the car been sitting for a few hours, when this happens? Did you have your AC on? If so sounds like the condensation didn't evap the water from the condensor. Stagnant water will cause this smell.
09vGT
Post by 09vGT »
Yeah, the car has been setting for a couple of hours when it happens... but... it doesn't smell like that all the time.. Like today when I came home from school. The car had been setting for like four hours in 97 degree heat... air was used in the morning when i went for school. But, when i start the car and start to drive the air smells fine, like a new car smell. I have about a 45 minute commute and after driving for about 20 minutes is when i gunned it to pass another car on a two lane road. Then thats when the smell hits.. all at once... then as im cruising down the road it goes away. Is this something i should have the dealer check out.. Its an 09 GT.
Kincaid
Post by Kincaid »
My 2009 with 2k miles has never done anything like that. I have no idea.But that doesn't stop me from a wild a$$ guess.High sulphur gasoline?
tribalman
Re: (Kincaid)
Post by tribalman »
i have the same smell when i go to gun it too. i think it just might be a few things at once; high sulfur gas and the cat working really hard.
None. Vibe is gone.
Jyik40
Post by Jyik40 »
Do you have the manual transmission or the auto? I've been noticing that on my 09 GT, the clutch squeeks a bit when I am driving slow. It happens especially when I feather the clutch.
Vibe17
Re: Question... possible problem (L5K)
Post by Vibe17 »
"Whooop - Whooop" - Bub RubBub Rub and Little Sis, hilarious.
09vGT
Post by 09vGT »
Its an auto transmission..
vibolista
Re: (09vGT)
Post by vibolista »
Quote, originally posted by 09vGT »I have about a 45 minute commute and after driving for about 20 minutes is when i gunned it to pass another car on a two lane road. Then thats when the smell hits.. all at once... then as im cruising down the road it goes away.Never heard anything like this happening before. But there's a simple way to make sure your Vibe GT doesn't pass those stink bombs ever again. Don't gun your car.
03VibeOttawa
Post by 03VibeOttawa »
Quote, originally posted by L5K »Did you have Bub Rub install a whistle tip for you or something? http://www.youtube.com/watch?v...ex=10 "It's just decoration, man. That's it and that's all."Haha, thanks for the link. Did anyone else come across the remix? It's so absurd I find it funny!http://www.youtube.com/watch?v=jpl_ey5cVnk&NR=1
03VibeOttawa–’03 Salsa 5spd. Fast Wheels Blade 17”s/Fuzion Zr1s (summer),Blizzak Revo1/’04 WRX rims, (winter),Tokico HP Struts,Tein S-Tech Springs,Progress RSB,K&N Typhoon SRI,SLP ram air hood,Magnaflow CB,DC header. Sold 11/9/2012 w/ 217,633kms.
L5K
Re: Question... possible problem (Feelin' The Vibe)
Post by L5K »
That remix reminds me of the Alabama Leprechaun http://www.youtube.com/watch?v=nda_OSWeyn8 And the remix that accompanied it as well. http://www.youtube.com/watch?v=gTYhwf_3so8 The "amateur sketch" makes me laugh every time...
LaPlanteys2010vibe
Post by LaPlanteys2010vibe »
Anybody know exactly what these front plastic flaps do on the 2009 & 2010 vibes?
vibolista
Re: Question... possible problem (LaPlanteys2010vibe)
Post by vibolista »
They are little aerodynamic devices that help you get slightly better gas mileage.
LaPlanteys2010vibe
You would think it would block the wind resulting in poor gas milage...hmmm Thanks you come through again!
