Install Tow Hitch 2009 2.4
markd78
Post by markd78 »
Installed U-Haul hitch on my 2009 2.4 Vibe. Easy, no problems, took 20 minutes. You need 19mm socket, 10" 3/8's extension, ratchet and torque wrench. On the muffler side, pull down on the exhaust tip to side hitch in. Hand tighten bolts, then torque to 65 lbs. http://s174.photobucket.com/al...eshow
MotoXdog
Re: Install Tow Hitch 2009 2.4 (markd78)
Post by MotoXdog »
Just installed mine last week. Can't get easier than that! (well, unless you have someone else do it for you ) I threw a little Lock-tight on the threads for good measure. Lighting kits are almost as easy as the hitch to install! Remove the connector from each tail light assy. and plug in the "T" connectors and just run a power wire to the battery. Only have to splice 2 wires!
'09 V-Base RHM w/Pinstripe
markd78
Re: Install Tow Hitch 2009 2.4 (MotoXdog)
Post by markd78 »
DId you run the power wire thru the interior or chassis ?
Kincaid
Post by Kincaid »
So, what is the towing capacity for the 2009 Vibe 2.4L?
kowell
Post by kowell »
1,500 lbs regardless of the engine choice.
2009 Vibe 2.4L 1SC - Red Hot Metallic
2011 Sienna V6 CE - Sky Silver
Kincaid
Post by Kincaid »
Guess that pop top tent trailer I was looking at is out.
Banjovibe
Post by Banjovibe »
Then look another, albiet smaller one.
We live our lives by the choices we make. I chose Vibe
