Where can I find a cap that you lift up to access the transmission to put it into neutral if you do not have the key in the ignition?It's located to the upper right of the gear shift lever, round about 1/3 of an inch in diameter. Mine was missing since I got it.A part number would be appreciated.MSAGRO
Sounds about like the climate control lights.Toyota Matrix $9.95Pontiac Vibe $24.99
03 GT, Abyss with tupperwareTo Do List: (will take a long time)Front/Rear swaybarsStrut tower barTint windowsReplace rear bumper cover (previous owner rear-ended)Replace upper front bumper cover (cracked)Replace VVTL-i engine cover (previous owner was Hercules)
