A/C problem on 03 GT
BrownBikePhoto
Post by BrownBikePhoto »
I've searched and came up with a few ideas but once people figure out how to fix the problem they leave ya hangin. My A/C clutch will not engage. I checked the fuse and replaced the relay. It engages when I jump the relay in the junction box. The problem must be before the fuse. Tomorrow I'm gonna rig a switch straight to the relay so I have A/C on the way down to the Outer Banks. Once I figure out the problem and how to fix it I'll post a vid or pictures of what I did. Any help would be great.
Jeremy A2003 GT with ****ty Nav Systemhttp://www.brownbikephotography.com/blog
wyatt89
Re: A/C problem on 03 GT (BrownBikePhoto)
Post by wyatt89 »
Check your pressure in the lines, if it's too low then it wont let the clutch engage. Might be the same if it's too high as well. I would check that first and if it's low then have it recharged and you'll be good to go.
'04 lava GTSRI, Progress rear sway bar, Infinity reference backs, components in the front, Infinity Kappa 124.7w sub, Alphasonik 600rms@2ohms for the sub, alpine head unit, worst paint ever!
BrownBikePhoto
I'll for sure check that tomorrow.
BrownBikePhoto
I ended up at the dealership today. Freon was low so the pressure switch wouldn't kick on the compressor. They charged it and put some dye in there. The guy said it could of just seeped out over time. So far no leaks! I'm glad I didn't put that switch on now. Cost me 90$ plus the 32$ for the relay I didn't need.
wyatt89
Post by wyatt89 »
Told ya Glad you figured it out!
jake75
Re: A/C problem on 03 GT (wyatt89)
Post by jake75 »
Quote, originally posted by wyatt89 »Check your pressure in the lines, if it's too low then it wont let the clutch engage. Might be the same if it's too high as well. I would check that first and if it's low then have it recharged and you'll be good to go.Wyatt89 - you are a genius!
wyatt89
Post by wyatt89 »
Meh, it's the same for most cars. My compressor clutch literally fell off so I'm on the hunt for a new one
