K&N Typhoon kit
Wolfman213
Post by Wolfman213 »
If i remember correctly the 03 & 04 react better to the CIA. The 05+, when they went Drive-by-Wire, reacts better to the SRI
lovemyraffe
Re: (xmasguy)
Post by lovemyraffe »
Try these guys. I know some other members have used them. http://www.cosmoracing.com
BadBrew
Re: (lovemyraffe)
Post by BadBrew »
Quote, originally posted by lovemyraffe »Try these guys. I know some other members have used them. http://www.cosmoracing.com +1, Cosmo CAI for my '05
2005 Lava Vibe base Garage
petervibe
Post by petervibe »
I am thinking in adding CAI to my 06 1.8 . Any experience with this item? Will it realy do anything performance wise or any difference in gas mileage better or worse ? thanks , Peter PS Cosmo has one for 95.00 +
06 Vibe stock for now 84 Carrera911also white 00 Mustang GT vert. 5spd.
BlueCrush
Re: (xmasguy)
Post by BlueCrush »
I have had Cosmo and aFe SRI's in the past and both worked very well. you can acheive better gas mileage when you nor gunning it. It will give you more HP in the mid to upper rpm range but will sacrifice somw low end torque. It sounds cool so you may find yourself wanting to hear that sound which will in turn lower your gas mileage. If you can control yourself then it should work well for you.Peter: I still have the shiny nuts for sale if you still want them. I IMed you several times without a response after you said you wanted them.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
petervibe
Re: K&N Typhoon kit (xmasguy)
Post by petervibe »
Sorry for the delay, I still don't know how to find the in coming box !! yes I am interested. sent an IM . Need an address. thanks , Peter
BlueCrush
Re: K&N Typhoon kit (petervibe)
Post by BlueCrush »
Quote, originally posted by petervibe »Sorry for the delay, I still don't know how to find the in coming box !! yes I am interested. sent an IM . Need an address. thanks , Peter Look here to view your IM's: http://forums.genvibe.com/zerothread?id=24877Or click on the IM button below MY name and hit send to see my IM's to you.
My Fleet:
