Slight wobble on '09 2.4L?
thepachman
Post by thepachman »
Hi all -I have had my 09 vibe 2.4L for just over a month now, and Im noticing a slight up and down wobble on roads that I feel are not quite as bumpy. As I put my head back to my headrest, it doesn't stay there, but instead bounces off of it. When I look at my keys, they are jiggling much more than I remember happening in any of my other cars.Is this rough of a ride normal and just based on the difference in suspension / tires or could something be wrong?Thanks for the help!
ou.grizzly
Post by ou.grizzly »
What roads are you driving?What size tires are on your Vibe?Do you have an AWD, Base, or GT Vibe?
thepachman
Re: (ou.grizzly)
Driving on paved roads, including newly paved 4 lane highways, expressways and rural roads. 17" aluminum wheels with the stock Eagle RSA tiresbase 2.4L
ou.grizzly
It is the tires and suspension more than likely...
thepachman
Re: (ou.grizzly)
But what about them would cause this? It's disconcerting and not something I thought would be normal for a brand new car.
ou.grizzly
Just the suspension and tire combo... I am pretty sure the 16" steel rims ride better just as the AWD Suspension does.
Sublimewind
Post by Sublimewind »
I would first take it somewhere and have the balance checked... they can also check for out of round... Could be a broken belt in one of the tires.. I doubt it has anything to do with wheels/tire size, not if the tires are mounted and balanced properly..
thepachman
Re: (Sublimewind)
Quote, originally posted by Sublimewind »I would first take it somewhere and have the balance checked... they can also check for out of round... Could be a broken belt in one of the tires.. I doubt it has anything to do with wheels/tire size, not if the tires are mounted and balanced properly.. That's what I was thinking, especially as I test drove one with the same wheels and don't remember it doing that. I'll call the dealership and get it in, hopefully it's just a balance issue or something like that.
Check all 4 tires and see if those little grey lead weights are there... I threw one once in the Sunfire (right front if I recall correctly) and you could feel the wobble in the car and steering. Wal-mart re-balanced it for free.
