Fan Switch 2006 Vibe
NancyBrnsn
Post by NancyBrnsn »
Fan switch, resistor, whatever. Should be repaired at no charge to owners.
BlueCrush
Re: Fan Switch 2006 Vibe (NancyBrnsn)
Post by BlueCrush »
Are you having problem with the fan not working or only working on high? If so, is the blower motor resistor that is in need of replacement not the switch. Tell us what is happening so we an help you out.Welcome to GenVibe, btw.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
NancyBrnsn
Re: Fan Switch 2006 Vibe (BlueCrush)
Hey - thanks for the welcome. I love my Vibe, but this motor resistor has been out since last fall. (About the same time as I had to switch from A/C to heat.) So, what do I have to do about getting it fixed?
BlueCrush
Post by BlueCrush »
The part# is in here: http://forums.genvibe.com/zerothread?id=23496And the How-to is in here (on the second half of the thread): http://forums.genvibe.com/zerothread?id=36099Hope this helps!
My Fleet:
NancyBrnsn
Thanks Crush. I will get the part and fix it myself. It should be easy. I won't even get greasy.
BlueCrush
Post by BlueCrush »
No problem. It should be an easy fix. Let us know how it goes and if you have any more questions.
My Fleet:
