Right on Raven. But the fit is identical on the Vibe bumper, so it gets (justifiably) advertised both ways by vendors selling the item. Some Matrix parts cross over fine.FYI: the 2009-2010 OEM protector for the Vibe is (as for earlier models) inferior to that built for the matrix (but not the vibe) aftermarket by Bushwacker.
http://www.bushwacker.com/bump...s.aspThis 2009 Matrix protector is not a perfect fit on the vibe but it is very close -- acceptably close for some people. The curvature on the inner edge is just a millimeter or so larger than the Vibe bumper line. Still, the outer edge fits fine and I went ahead and installed it on mine because of the much superior protection it offers compared to the Vibe OEM (I haul bikes in the back and the wimpy OEM one doesn't do much to prevent pedal clips). You have to look pretty hard and scratch your head to determine its a misfit. Metso not to confuse -- the 03 protector mentioned above (or the OEM one cited by Raven) are your two choices. But the point is, sometimes Matrix accessories work, sometimes they don't and sometimes they "sorta work"
