2008 Rear Window Sprayer: Spray or Stream?
jamesmovespeople
Post by jamesmovespeople »
Took my Vibe into the dealer because the rear spritzer doesn't spray, it streams. Two jets covering the central quarter of the rear window. No mist, no spray, just a stream. They replaced it, and now it streams in a bit wider pattern, but still jets. Service manager tried the sprayer on a 2009, and same deal: streams. Is this normal?
BlueCrush
Re: 2008 Rear Window Sprayer: Spray or Stream? (jamesmovespeople)
Post by BlueCrush »
Welcome to GenVibe!!! Yeah. Mine's more of a dribbler. It has always done it from day 1.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
ToolGuy
Post by ToolGuy »
Yes, very normal. Be glad you do not have an 03. The rear squirter was one stream, no mist. Later changed on 2004 and up to two. I have updated my rear squirter to the two stream part. Makes a big differenece in the winter.
lovemyraffe
Post by lovemyraffe »
Mine has two streams. I wish it was more of a spray.
Herb
Re: 2008 Rear Window Sprayer: Spray or Stream? (BlueCrush)
Post by Herb »
Quote, originally posted by BlueCrush »Welcome to GenVibe!!! Yeah. Mine's more of a dribbler. It has always done it from day 1. I kinda equated it to drooling. I've also upgraded mine to the dual streams as opposed to the single one mine originally had
The '09 mists nicely. We'll see what happens given time.
