Any tips on launching an '05 GT smoothly?? Seems to have a tricky clutch and/or not much low end torque. I've pretty much got a handle on the heel and toe down shifting for "on the go grabbing gears," but I've not been able to figure out the launch. When it's wet, I get some pretty violent wheel hop...doesn't sound good. Every once in a while I'll come across the sweet spot, but it's not very reproducible. Any advice from the Vibe Goo Roo's?
Quote, originally posted by northvibe »yes they would help stiffen the engine mounts and help wheel hop, so would better tires.well...yeh, the tires are the ones that came from the dealer when we got it last fall...they were brand new! Dunlop Signature something or other...looks like a good wet treat pattern. Thanks for the info. I was unaware of the engine mount issue...I'm thinking poly mounts probably also transmit more NVH, huh?
If you are launching on a track the thing that gives me the lowest 60ft is to rev it up to around 6k (or the first limiter) and slip it until the rpms climb fast without wheel spin.My clutch is pretty bad so once the car starts moving i can pretty much just release it and the rpms will catch up.Doing this I've run a 10 flat in the 1/8th mile If it's wet it's pretty much a worthless cause, no lsd and lots of wheel hop make it next to useless.
'04 lava GTSRI, Progress rear sway bar, Infinity reference backs, components in the front, Infinity Kappa 124.7w sub, Alphasonik 600rms@2ohms for the sub, alpine head unit, worst paint ever!
