S/C grinding .... again
Supercharger, turbo, nitrous, and anything that has to do with forced induction
4azdmunky
Post by 4azdmunky »
So, now that I've had the car running for a little over a month without any issues, the S/C started grinding again. Its not as bad as last time where it sounded like a rock tumbler, but each day it gets a little worse. Not looking forward to another $800 rebuild bill on this thing, anyone know how to make these things more reliable? Does anyone know if Magnuson has TRD nose assemblies? Their web site doesnt say.How about an oil change? Does it have to have S/C oil or would Royal Purple Gear Oil work?
satur9
Re: S/C grinding .... again (4azdmunky)
Post by satur9 »
mabey try gatorback belt with slightly less belt tension. or fab up a bracket to hold the nose up
4azdmunky
Re: S/C grinding .... again (satur9)
Post by 4azdmunky »
I already have a gatorback belt, I was wondering if it was 1/2 a rib off or something and was causing a vibration. I'll check that out in the morning.Thanks!
DiveNut
Post by DiveNut »
Is it grinding when you start it up or when you are under load/in boost? A little noise at idle is normal. Especially until you reach operating temperature. However, it should smooth out when your RPMs get above about 1200-1500 RPM or so. Doe she smooth out at idle when your temps get up? If so, I believe you are OK.
Bare Bones Base, Abyss 2004 Vibe, Debadged, Auto, ABS, GM Performance Supercharger, Injen CAI, 2.3" URD Pulley, Unichip,Tru-Cool Tranny Cooler SOLD
1972 Plymouth Duster 340 (Strip/Street Project)
4azdmunky
Re: S/C grinding .... again (DiveNut)
Post by 4azdmunky »
lucked out, turned out the pulley was loose. A little LOC-Tight and a socket, and its all fixed.
DiveNut
Post by DiveNut »
Quote, originally posted by 4azdmunky »lucked out, turned out the pulley was loose. A little LOC-Tight and a socket, and its all fixed.Good deal!
Petrucci914
Post by Petrucci914 »
Quote, originally posted by 4azdmunky »I already have a gatorback belt, I was wondering if it was 1/2 a rib off or something and was causing a vibration. I'll check that out in the morning.Thanks!Don't use Gatorback belts on the SC'er. Trust me.
2003 Pontiac Vibe Base - AutomaticTRD Supercharger w/ Smoothflow PulleyaFe Drop-in Filter - DC Sports HeaderFull 2.25" Exhaust -Magnaflow Catback + CatsOptima RedTop - Tru-Cool Tranny Cooler
4azdmunky
Re: S/C grinding .... again (Petrucci914)
Post by 4azdmunky »
Hmmm. what happened?
