Quote, originally posted by oliverh72 »Thanks for the quick response!If Pam's does ever have the stock MP3 deck, will that work with the Monsoon? So, since you've gone aftermarket, what are the issues (wiring harnesses, etc etc) I should be aware of if I go this way? Can any deck plug into the amp to run the sub? Thanks,OliverNo prob on the response, I can't answer the MP3 stock deck? I would like to say yes, but I don't know.Wiring harness isn't an issue, on a AfterMarket Deck, you don't have to do anything weird just because it has a seperate Amp. There are a few threads here in regards to Installs, the most recent one I remember is Blue Crush's install:
http://forums.genvibe.com/zerothread?id=37490You can do a search for 'head unit' and you'll find them. I know Sublime has one and I believe Keith does too.I didn't use a Line Out Gain Adjuster, I probably could/should have.. maybe some other day...
