Which is the correct off set for after market alloys ? I found 16" Celica GT wheels , the seller states they have an off set of 55. 16x 7 Would that fit ? Please let me know someone. So I know if i should buy them. thanks,Peter
06 Vibe stock for now 84 Carrera911also white 00 Mustang GT vert. 5spd.
Quote, originally posted by petervibe »I am told that Toyota uses 5x100 pattern. Thats the same as the Vibe, right ? If you have a 03-08 Vibe then yes the 5x100 is correct.
Vibe/Matrix offsets for the 03 thru 08s range from 39 to 45mm. The 16 inch steel and alloy wheels are 39mm and the 17 inch alloy has a 45mm offset. Don't know if they changed offsets for the 09 mondel year. A 55mm offset would put the outside edge of the wheel about 10mm farther inside the wheel well than the 45mm. I bought a 38mm offset 17 inch wheel to bring the tire and wheel out to the edge of the Vibe wheel well lip. Ended up almost flush... just a few mms from the edge.
