Vibe 2009 1.8 FWD Harsh 1st gear shift
lhrn
Post by lhrn »
Sometimes my first gear change is a bit harsh. If feels like the car was pushed from behind (a liitle bit). It specially happens when the car is cold. I do not know whether it is normal with four cylinder cars.
Wolfman213
Post by Wolfman213 »
lhrn
Re: (Wolfman213)
Post by lhrn »
Thank you for your response. I've seen that thread before but my problem is opposite. When I go from 1st to 2nd it is harsh. Not when I stop
Wolfman213
ahh, gotcha. Well, for that, hopefully someone else will chime in bc I have no clue. good luck in your search for smooth shifts!
Try to match rpm's when you shift. Drain the tranny and see if there are any metal fragments in the fluid(hope there's none!)I once had an old '81 Toyota pick-up that started doing that(except it was 2nd to 3rd)... I soon traded it in for my Sunfire
