Wiring Diagram
techren
Wiring Diagram
Post by techren »
Does anyone happen to have a diagram showing the hatch glass release? The button on my dash stopped working and I would like to fix it. Already tested the switch it is OK.Any help here would be great.Thanks!!
Sublimewind
Post by Sublimewind »
What do you need to see? If you pull the rear hatch panel off, it's right there... You would want to check the line there to see if you are getting 12v and if so, it's likely the solenoid.. pretty straight forward..
techren
Re: (Sublimewind)
Post by techren »
I need the routing from the button on the dash to the control module. I installed it myself when I got the car. At the time I had the diagram but I seem to have lost it. It worked for a long time but I think one of the wires, there are only two running to the switch, may have come loose.It is rather difficult to see things up under the dash so the diagram would tell me where to focus.
