well that's an odd thing.I bought the expensive massivefactory service manual set, two large volumes. VOlume one pretty much covers the engine, VOlume two covers all the wiring stuff. Somehow I stupidly lost Volume 2 and I was using the downloadable Matrix service manual. I fully expected the headlight circuit to the the saem, but apparently it isn't, because I just went out and looked in my car, and you're right, there are no fuses there.There are two 15 Amp fuses marked left and right headlamp, so maybe it's one of those. However, without the real Vibe wiring diagram for the headlamps, I can't tell if those are for low beams, high beams, or both. Also, I can't look up to see what else might cause the problem if the fuses are good. Anyway, the fuse locations (Page 5-100 in the 2004 Vibe owners manual, available at
http://forums.genvibe.com/zerothread?id=1010 ) areif those are both good, then we'll need someone who hasn't stupidly lost Volume 2 of the service manual to look up and post the headlamp wiring diagramsorry about posting bad info before
